does anyone know if it is possible to use a user defined parameter to drive a action parameter.
I have several polar and linear stretch actions i would like to drive from one parameter.
i think i have attached my dwg.
the block name is config1
FOAM_DRAIN_PAN_DYN_BLOCK.dwg
I don’t think a lookup parameter will work
the drain pan size could be anything from 44" to 600"
there would be to many combinations to use a look up parameter
The only other thing you can do is to do some visual lisp as you can change values in the list of the dynamic block.
Type list enter
All the values there you should be able to get to.
