CADEveryDay Posted February 6, 2024 Posted February 6, 2024 On 2/1/2024 at 4:59 PM, BIGAL said: Remove the select bname line and add your block name "asdf" where bname exists in the ssget and all done, rename the defun to something more useful. (defun c:eblk ( / Block_name ss) (setq ss (ssget "Block_name" '((0 . "INSERT")(cons 2 Block_name)))) (command "erase" ss "") (princ) ) I think I'm close with the attached code but its not quite there. If someone could explain what I'm doing wrong, I would appreciate it. Quote
BIGAL Posted February 6, 2024 Posted February 6, 2024 (edited) (defun c:eblk (Block_name / ss) (setq ss (ssget "X" '((0 . "INSERT")(cons 2 Block_name))) or (setq ss (ssget "X" '((0 . "INSERT")(cons 2 Block_name)(cons 410 (getvar 'ctab))) ; current space only Edited February 6, 2024 by BIGAL Quote
