Brant6 Posted February 1, 2012 Posted February 1, 2012 When you extract information from attribute blocks to form a spreadsheet can you specify that the spreadsheet also lists the co-ordinates x,y, z for that blocki? For example, you have an attribute block with information regarding, station number, chine number. When I extract the information I would like to list the x, y co-ordinate point of the circle block Regards, Brant6 Quote
BIGAL Posted February 2, 2012 Posted February 2, 2012 The insert point of a block is just another part of the information available when you enquire on a object properties if using ssget then assoc 10 will give you the answer you want, VL will have something like VL-block-insertpt. Quote
edwinprakoso Posted February 10, 2012 Posted February 10, 2012 If you want to report specific or multiple coordinate, you can try this: http://cad-notes.com/2009/12/reporting-multiple-coordinates-in-a-block-using-attribute-extraction/ Quote
