one25IT Posted January 31, 2012 Posted January 31, 2012 I was able to create palettes manually adding AEC objects from the Design Tool Catalog through the Autodesk Content Browser. Still, the English catalog library doesn’t feature all the AEC objects seen in the German version of Autocad Architecture in Youtube tutorials. Does anybody know the reason for that, or a source to find more design styles for stairs and railings? Quote
tzframpton Posted February 1, 2012 Posted February 1, 2012 Have you opened the Styles DWG File that contains all the stairs and railings to see if there's more available? Quote
one25IT Posted February 1, 2012 Author Posted February 1, 2012 I was able to discover 'Stair Styles.dwg'. It contains the 8 types from above plus two more (Standard and Ramp-Steel). I guess that's what there is; this might be due to regional practices. Thanks StykFacE! Quote
tzframpton Posted February 1, 2012 Posted February 1, 2012 Good deal, glad it worked out for you. Remember that for all the other Styles too, in case you ever run into that problem again. Quote
