norm Posted January 30, 2012 Posted January 30, 2012 This is the message i receive when i send a file to be printed Can someone help Quote
Strix Posted January 31, 2012 Posted January 31, 2012 the more info you can give in your original post, the better chance somebody has of helping locate the problem does this happen using different printers? what settings are you using? which printer are you using? are your printer drivers up to date? did it work properly in the past? Quote
ReMark Posted January 31, 2012 Posted January 31, 2012 That message is too generic to be useful. Were you printing a 2D or 3D drawing? Are you working off a network or standalone? What version of AutoCAD are you using? What OS are you running? Does this happen with every drawing you are trying to print or just this particular drawing? Did you try shutting down your computer, restarting, loading AutoCAD then trying to print again? Is this a first time occurrence? Have you ever been able to print from this computer in the past? Quote
