Hi All
Does any one have a Lisp routine to turn the diagonal line that chamfer creates to the current layer instead of the original layer of the lines? I would appreciate any help.
Thanks
Brian
Is your stated version (2000i) an older LT version? Is it LISP capable?
(defun c:Chamfer2 (/ ent)
 (setq ent (entlast))
 (command "_.chamfer")
 (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (command PAUSE))
 (if (not (equal ent (setq ent (entlast))))
   (entmod (list (cons 8 (getvar 'CLAYER)) (cons -1 ent)))
Thanks that is exactly what i was looking for...
But when chamfering a Polyline object while Trimmode variable is set to zero, there may be more than one object as the result of CHAMFER.
For this case alanjt's nice code can be edited to:
[b][color=purple](while (setq ent (entnext ent))
 [/color][/b](entmod (list (cons 8 (getvar 'CLAYER)) (cons -1 ent)))
  Lee Mac said:
Be careful when 'entlast' is an Attribute Block or Polyline. ;)
I checked Polyline and it doesn't cause any error on VERTEX and SEQUEND objects, but changes ATTRIB objects. So the code can be edited to this one:
 (or
  (member (cdr (assoc 0 (entget ent))) '("ATTRIB" "VERTEX" "SEQUEND"))
