How to export table in Autocad to Excel file ?
hi
i want export all my data in table autocad sheet to excel !?
what can i do ?
What form does this data take? Attributes?
AutoCAD 2007? I'm thinking you would have to use the EATTEXT command.
OK...I've got to hit the road here in a few minutes. I think this might help you. Go to page 6 for a description of the EATTEXT command.
http://www.lukewarmcoffee.com/cad/AUGI%20-%20Data%20Extraction%20in%20AutoCAD.pdf
EAT TEXT - Data Extraction in AutoCAD by Dave Espinosa-Aguilar (AutoDesk University 2007 - course #GD205-4P).
Edited by ReMark
thanks for post
but i want only in data in table to excel export !!
forexample : files attached
in files attach all data in DWG file export to XLS file
how can i do it easy doing to do !!!
XLS.xls
Since you did not post an answer to my question about what form the data was in I made a guess (attributes). Looks like I was wrong.
How did you create your table?
  • 4 years later...
DWG to XLS app is another solution
You can try this app
