CaveMan Posted January 27, 2012 Posted January 27, 2012 Good Day How does one program to draw an arc(Point, Radius, Angle, Angle) The arc keeps getting drawn according to the WCS? The angles Relate also to the WCS. If a line gets drawn from two Point3D - no problem about the ucs - but arcs and circles retain to WCS even if the user has changed to a UCS? Aye Help needed here Even if just a simple example to draw an arc on current user UCS will be Great Cheers CaveMan Quote
BlackBox Posted January 27, 2012 Posted January 27, 2012 These links may be of use: AutoCAD .NET Developers Guide, here's a snippet: Stephen Preton, AutoCAD .NET Developers Guide, Pages 181-182 said: Create an Arc object This example creates an arc in Model space with a center point of (6.25,9.125,0), a radius of6, start angle of 1.117 (64 degrees), and an end angle of 3.5605 (204 degrees). VB.NET Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Namespace FOO Class Foo <CommandMethod("AddArc")> _ Public Sub AddArc() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create an arc that is at 6.25,9.125 with a radius of 6, and '' starts at 64 degrees and ends at 204 degrees Dim acArc As Arc = New Arc(New Point3d(6.25, 9.125, 0), _ 6, 1.117, 3.5605) acArc.SetDatabaseDefaults() '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acArc) acTrans.AddNewlyCreatedDBObject(acArc, True) '' Save the new object to the database acTrans.Commit() End Using End Sub End Class End Namespace Convert Angle from UCS to WCS Calculating the Angle Between UCS and WCS HTH Quote
CaveMan Posted January 30, 2012 Author Posted January 30, 2012 (edited) Cheers Thanks for the source code supplied Will review it when i have a chance Below is the two public modules i created - which also works. Highlited in red was my mistake - Arc was not transformed to current ucs. ______________________________________________________________________ Code: PublicModule ModDrawArc FriendFunction DrawArc(ByVal startPoint As Point3d, ByVal Radius AsDouble, ByVal StartAngle AsDouble, ByVal EndAngle AsDouble) As Arc Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database acDoc.LockDocument() Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim acArc As Arc = New Arc(startPoint, Radius, StartAngle, EndAngle) [color=red]acArc.TransformBy(GetUcsMatrix(acCurDb))[/color] acBlkTblRec.AppendEntity(acArc) acTrans.AddNewlyCreatedDBObject(acArc, True) acTrans.Commit() [size=2][size=2][color=black]End[/color][/size][/size][size=2][size=2][color=black]Using[/color][/size] [/size][color=black][size=2][size=2]End[/size][/size][size=2][size=2]Function[/size][/size][/color] [size=2][color=#0000ff][size=2][color=#0000ff]_____________________________________________________________[/color][/size][/color][/size] [color=black] [/color] [color=black][size=2][size=2]Friend[/size][/size][size=2][size=2]Function[/size][/size][size=2] GetUcsMatrix([/size][size=2][size=2]ByVal[/size][/size][size=2] db [/size][size=2][size=2]As[/size][/size][size=2] Database) [/size][size=2][size=2]As[/size][/size][size=2] Matrix3d[/size][/color] [color=black][size=2][size=2]Dim[/size][/size][size=2] origin [/size][size=2][size=2]As[/size][/size][size=2] Point3d = db.Ucsorg[/size][/color] [color=black][size=2][size=2]Dim[/size][/size][size=2] xAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = db.Ucsxdir[/size][/color] [color=black][size=2][size=2]Dim[/size][/size][size=2] yAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = db.Ucsydir[/size][/color] [color=black][size=2][size=2]Dim[/size][/size][size=2] zAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = xAxis.CrossProduct(yAxis)[/size][/color] [color=black][size=2][size=2]Return[/size][/size][size=2] Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, _[/size][/color] [size=2][color=black]Vector3d.ZAxis, origin, xAxis, yAxis, zAxis)[/color][/size] [color=black][size=2][size=2]End[/size][/size][size=2][size=2]Function[/size][/size][/color] Appreciate Cheers CaveMan Edited February 3, 2012 by CaveMan Quote
SLW210 Posted January 30, 2012 Posted January 30, 2012 CaveMan, Please read the CODE POSTING GUIDELINES and edit your post. Quote
