AHL808 Posted October 22, 2008 Posted October 22, 2008 I am using Autocad 2008 to publish a job to Adobe PDF (or any plotter for that matter). When I plot the sheets individually they work fine. The only problem is I now have to plot every sheet indivudually since publish dosent work. What happens is when I go to publish the job sends as usual then it stops @ "Publish Job in Progress". I've waited about half an hour for the job to process but nothing happens. Any thoughts? Thanks! Quote
ReMark Posted October 22, 2008 Posted October 22, 2008 When printing to a printer make sure PUBLISHCOLLATE variable is set to 0 Also go to Tools, Options, Plot and Publish and uncheck both squares that allow background plotting. Quote
