Droselle Posted January 23, 2012 Posted January 23, 2012 I'm having trouble with the "extend" function on AutoCAD 2012 (windows). Randomly, the "extend" function will delete the lines I select. I sometimes will have to undo and re-input "extend" three to four times for it work properly. No, this isn't a major issue however, it is certainly irritating after hours of use. Has anyone else experienced this? Quote
Jack_O'neill Posted January 23, 2012 Posted January 23, 2012 Is it actually deleting the line or is your video card losing it? Next time that happens, try a regen before you do anything else and see if the missing entities come back. If they do, you 'll need to upgrade your video arrangement. Quote
JD Mather Posted January 23, 2012 Posted January 23, 2012 Attach a file here that exhibits this behavior. Quote
