press21 Posted January 21, 2012 Share Posted January 21, 2012 I have been fumbling with this for a while now, I dont know why i cant make this work. The extrude wont work because the self intersection circles, but i thought it would presspull, but it does not. i attached a jpg. Any ideas?? Press Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 21, 2012 Share Posted January 21, 2012 Here is an idea - attach the file here. (dwg that is, I'm not familiar with editing jpgs in AutoCAD and of course it is impossible to locate the problem in that jpg attachment) Why not eliminate any self-intersection? Looks to me like a continous non-intersecting boundary could be created from that profile. Quote Link to comment Share on other sites More sharing options...
press21 Posted January 21, 2012 Author Share Posted January 21, 2012 Branches v5.dwg i guess i should have put this up in the first place. I could not find anything that intersected. press Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted January 21, 2012 Share Posted January 21, 2012 I exploded your polyline, ran overkill, then pedited it back together. Extrudes just fine then. You can probably skip the explode part and just use overkill. You had a bunch of overlapping line segments. When there's a problem, I like to get back to basics, so I explode stuff. I zoomed up a bit and changed it's color just show it would up better in the png file. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 22, 2012 Share Posted January 22, 2012 I exploded your polyline' date=' ran overkill, then pedited it back together. Extrudes just fine then. You can probably skip the explode part and just use overkill. You had a bunch of overlapping line segments. When there's a problem, I like to get back to basics, so I explode stuff. [ATTACH=CONFIG']32447[/ATTACH] I zoomed up a bit and changed it's color just show it would up better in the png file. Overkill is the perfect tool for this, good call Jack. Much easier than trying to trace it. Looks good. :wink: Quote Link to comment Share on other sites More sharing options...
