Polyline change fra layer AM_0 til 0
elfert
I am trying to make a routine that could change all polylines in a drawing from layer AM_0 to 0. But i can't get i to work.
(defun C:chgpllnul ( / pllist )
(setq pllist ((ssget '((8 . "AM_0") (0 . "Polyline")))
(command "change" pllist "" "P" "LA" "0" "" )))
Please help!
Thx in advance.
(0 . "Polyline")
or for both
(0 . "*POLYLINE")
I think this work
(defun C:chgpllnul (/ pllist slen sname entlst)
 (if (setq pllist (ssget '((8 . "AM_0") (0 . "*Polyline"))))
   (repeat (setq slen (sslength pllist))
     (setq sname (ssname pllist (setq slen (1- slen))))
     (entmod (subst (cons 8 "0")
                    (assoc 8 (setq entlst (entget sname)))
                    entlst
I think this work
                    entlst
Neither #2 or #3 works. (using A2008) so ?
Without testing #3 myself (nothing jumps out to me as to why it wouldn't work?), you could always iterate the VLA ActiveSelectionSet Object, and use vla-put-layer Method as an alternative.
(defun C:chgpllnul  (/ pllist)
     (setq pllist (ssget '((8 . "AM_0") (0 . [b][color=darkolivegreen]"*Polyline"))))[/color][/b]
     (command "change" pllist "" "P" "LA" "0" ""))
from
(setq pllist [b][color=#0000ff]([/color][/b](ssget '((8 . "AM_0") (0 . [b]"[/b][color=blue][b]Polyline"[/b])))[/color]
(command "change" pllist "" "P" "LA" "0" "" ))[b][color=blue])[/color][/b]
and while we're at it
     (if (ssget '((8 . "AM_0") (0 . "*Polyline")))
                 (vlax-for
                        itm  (setq pllist
                                        (vla-get-ActiveSelectionSet
                                              (vla-get-ActiveDocument
                                                    (vlax-get-acad-object))))
                       (vla-put-layer itm "0")
                 (vla-delete pllist)
You could do this very easily with your action recorder, if you have your quick properties palette turned on to provide the POLYLINE filter selection, then just change the layer on the quick properties palette. Not sexy, but it would work.
You could always use QSELECT also... Just saying. :wink:
Edited by BlackBox
Point taken guys...
In fairness to the OP, he did ask for help why he cant get his code to work .. but then again it wouldnt hurt to know you can use native commands for such a task. ;)
You make a good point RenderMan. I have never used it before, have used FILTER though, looks pretty similar. I always use my quick properties palette, so get an awful lot of handy information and limited selectivity there, but I will definitely start using this, good tool, I've seen it mentioned a lot, thanks. :thumbsup:
Year i know that it possible to filter out using quick select. Just one problem we sometimes have a lot sheet metal cuts geometry that has to be a polyline and layer 0. So i need to write a routine ´that could easy find all Poly lines that is laying on AM_0 and move it to 0. Thx any way. I am thing about to make it more advance so it don't look only for layer AM_0 but any poly line that is different from layer 0. Any suggestion?
Give this a try :wink::
(defun c:FOO ( / ss)
 (if (setq ss (ssget "_x"
                     (list '(0 . "*POLYLINE")
                           '(8 . "AM_0")
                           (cons 410 (getvar 'ctab)))))
   (sssetfirst nil ss))
 (princ))
