Hi!
I have a PDF file (version 1.3) that I inserted into my drawing (AutoCAD 2010 LT) just fine, except the image won't show up. All there is the rectangular outline of the xref which I can select and move around, but inside the outline, a blank image where I expect a floor plan.
I am able to attach another PDF file (version 1.6) and see the image it contains just fine.
Does this have to do with the PDF version? Is there a way to convert it so I can see it on my drawing? Otherwise, what's going on?
Thanks for any helpful responses!
check what layer you inserted it on it might be turned off ?
Yes, I checked the layers. I did the same steps for the PDF image that wouldn't show up with a PDF image that did show up.
Could it be you have the layer locked when printing. I've done that before and it doesn't show up.
If possible, post the drawing file or at least the troublesome parts.
