Get and Set Lisp Variables VBA to VB .NET
FELIXJM
I have functions VBA for GET and SET Lisp variables. How modify for VB .NET
[size=2][size=2][color=#0000ff][size=2][color=#0000ff]Function[/color][/size][/color][/size][size=2] GetLispVariable([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] varname [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2]) [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Object[/color][/size][/color][/size][/size]
[size=2][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] VL [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Object[/color][/size][/color][/size][/size]
[size=2][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] VL [/size][size=2][color=#0000ff][size=2][color=#0000ff]Is[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Nothing[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Then[/color][/size][/color][/size][/size]
[size=2][size=2]   VL = CreateObject([/size][size=2][color=#a31515][size=2][color=#a31515]"VL.APPLICATION.16"[/color][/size][/color][/size][size=2])[/size][/size]
[size=2][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][/size]
[size=2][size=2][color=#0000ff][size=2][color=#0000ff]With[/color][/size][/color][/size][size=2] VL.ActiveDocument.Functions[/size]
[size=2]   GetLispVariable = .Item([/size][size=2][color=#a31515][size=2][color=#a31515]"eval"[/color][/size][/color][/size][size=2]).funcall(.Item([/size][size=2][color=#a31515][size=2][color=#a31515]"read"[/color][/size][/color][/size][size=2]).funcall(varname))[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]With[/color][/size][/color][/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Function[/color][/size][/color][/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size][size=2] SetLispVariable([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] varname [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2], [/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] value [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Object[/color][/size][/color][/size][size=2])[/size]
  [size=2].Item([/size][size=2][color=#a31515][size=2][color=#a31515]"set"[/color][/size][/color][/size][size=2]).funcall .Item([/size][size=2][color=#a31515][size=2][color=#a31515]"read"[/color][/size][/color][/size][size=2]).funcall(varname), value[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size]
[size=2][color=#008000][size=2][color=#008000]'PARA SETAR ==> SetLispVariable "nomevar", "Funciona!!"[/color][/size][/color][/size]
[size=2][color=#008000][size=2][color=#008000]'PARA PEGAR ==> MsgBox ReadLispVariable("nomevar")[/color][/size][/color][/size]
[/size]
OK.
Thank you.
FELIXJM
Thanks, I converted to VB.NET.
I need one more help, I am not expert in VB.NET, use only for display screens for Autolisp because the DCL is very rigid.
I just need the functions GETLISPSYM and SETLISPSYM to put in a MODULE in VB.NET
Can you help?
' CodeHimBelonga kdub@theSwamp
#Region "UsingRegion"
Imports System.Collections.Generic
Imports System.Linq
Imports System.Data
Imports System.IO
Imports System.Text
Imports System.Text.RegularExpressions
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports ACAD = Autodesk.AutoCAD.Interop
Imports ACADCOM = Autodesk.AutoCAD.Interop.Common
#End Region
<Assembly: CommandClass(GetType(kdub_Testing.MyCommandsClass))>
Namespace kdub_Testing
Public Class MyCommandsClass
	Private dwg As Document
	Private db As Database
	Private ed As Editor
	Public Sub New()
		ActiveDrawing = AcadApp.DocumentManager.MdiActiveDocument
	End Sub
	Private Property ActiveDrawing() As Document
		Get
			Return dwg
		End Get
		Set
			dwg = value
			If dwg IsNot Nothing Then
				db = dwg.Database
				ed = dwg.Editor
			Else
				db = Nothing
				ed = Nothing
			End If
		End Set
	End Property
	' Type of resbuf element
	' credit to Alexander Rivilis
	Const RTNONE As Short = 5000
	' No result
	Const RTREAL As Short = 5001
	' Real number
	Const RTPOshort As Short = 5002
	' 2D poshort X and Y only
	Const RTSHORT As Short = 5003
	' Short integer
	Const RTANG As Short = 5004
	' Angle
	Const RTSTR As Short = 5005
	' String
	Const RTENAME As Short = 5006
	' Entity name
	Const RTPICKS As Short = 5007
	' Pick set
	Const RTORshort As Short = 5008
	' Orientation
	Const RT3DPOshort As Short = 5009
	' 3D poshort - X, Y, and Z
	Const RTLONG As Short = 5010
	' Long integer
	Const RTVOID As Short = 5014
	' Blank symbol
	Const RTLB As Short = 5016
	' list begin
	Const RTLE As Short = 5017
	' list end
	Const RTDOTE As Short = 5018
	' dotted pair
	Const RTNIL As Short = 5019
	' nil
	Const RTDXF0 As Short = 5020
	' DXF code 0 for ads_buildlist only
	Const RTT As Short = 5021
	' T atom
	Const RTRESBUF As Short = 5023
	' resbuf
	Const RTMODELESS As Short = 5027
	' interrupted by modeless dialog
	' Error return code
	Const RTNORM As Short = 5100
	' Request succeeded
	Const RTERROR As Short = -5001
	' Some other error
	Const RTCAN As Short = -5002
	' User cancelled request -- Ctl-C
	Const RTREJ As Short = -5003
	' AutoCAD rejected request -- invalid
	Const RTFAIL As Short = -5004
	' Link failure -- Lisp probably died
	Const RTKWORD As Short = -5005
	' Keyword returned from getxxx() routine
	Const RTINPUTTRUNCATED As Short = -5008
	' Input didn't all fit in the buffer
	<System.Security.SuppressUnmanagedCodeSecurity> _
	<DllImport("acad.exe", EntryPoint := "acedPutSym", CharSet := CharSet.Unicode, CallingConvention := CallingConvention.Cdecl)> _
	Private Shared Function acedPutSym(args As String, result As IntPtr) As Integer
	End Function
	<DllImport("acad.exe", EntryPoint := "acedGetSym", CharSet := CharSet.Unicode, CallingConvention := CallingConvention.Cdecl)> _
	Private Shared Function acedGetSym(args As String, ByRef result As IntPtr) As Integer
	End Function
	''' <summary>
	''' </summary>
	''' <param name="name"></param>
	''' <returns>ResultBuffer</returns>
	Friend Shared Function GetLispSym(name As String) As ResultBuffer
		Dim ip As IntPtr = IntPtr.Zero
		If (acedGetSym(name, ip) = RTNORM) AndAlso (ip <> IntPtr.Zero) Then
			Return ResultBuffer.Create(ip, True)
		End If
		Return Nothing
	End Function
	''' <summary>
	''' </summary>
	<CommandMethod("DoIt1114a", CommandFlags.Modal)> _
	Public Sub DoIt1114a()
		Dim res1 As ResultBuffer = GetLispSym("TestVar1")
		Dim res2 As ResultBuffer = GetLispSym("TestVar2")
		Dim res3 As ResultBuffer = GetLispSym("TestVar3")
		Dim res4 As ResultBuffer = GetLispSym("TestVar4")
		ed.WriteMessage("{0} : {1}", vbLf & "Res1", res1.ToString())
		ed.WriteMessage("{0} : {1}", vbLf & "Res2", res2.ToString())
		ed.WriteMessage("{0} : {1}", vbLf & "Res3", res3.ToString())
		ed.WriteMessage("{0} : {1}", vbLf & "Res4", res4.ToString())
		If res4 IsNot Nothing Then
			Dim s As New StringBuilder()
			s.Append(vbLf & "******")
			For Each val As TypedValue In DirectCast(res4, System.Collections.IEnumerable)
				s.AppendFormat(vbLf & "{0} -> {1}", val.TypeCode, val.Value.ToString())
			Next
			ed.WriteMessage(s.ToString())
		End If
	End Sub
	''' <summary>
	''' </summary>
	<CommandMethod("DoIt1114b", CommandFlags.Modal)> _
	Public Sub DoIt1114b()
		Dim res As PromptResult = ed.GetString(vbLf & "Name of lisp-variable: ")
		Dim LispVarName As String = String.Empty
		If res.Status = PromptStatus.OK Then
			Dim rb As New ResultBuffer()
			LispVarName = res.StringResult
			rb.Add(New TypedValue(RTSTR, "This is the transported Text"))
			acedPutSym(LispVarName, rb.UnmanagedObject)
		End If
		ed.WriteMessage("{0} : {1}", vbLf & "Res1", GetLispSym(LispVarName).ToString())
	End Sub
	''' <summary>
	''' </summary>
	<CommandMethod("DoIt1114c", CommandFlags.Modal)> _
	Public Sub DoIt1114c()
'* Lets say we have an expectation that a Lisp List has a specific structure
'* of (list String Integer RotationAngle 3dPoint)
'* we need to build the ResultBuffer to suit.
		Dim resName As PromptResult = ed.GetString(vbLf & "Name of lisp-variable: ")
		Dim LispVarName As String = resName.StringResult
		Dim resStr As PromptResult = ed.GetString(vbLf & "Input String Value : ")
		Dim resInt As PromptIntegerResult = ed.GetInteger(vbLf & "Input Integer Value : ")
		Dim resAng As PromptDoubleResult = ed.GetAngle(vbLf & "Input or select Angle : ")
		Dim resPt As PromptPointResult = ed.GetPoint(vbLf & "Input or Select 3DPoint : ")
		' For the exercise, assume the values are Valid .... 'danger Will Robinson'
		' Use Tony's TypedValueList class to build the result buffer.
		Dim dataList As New TypedValueList()
		dataList.Add(LispDataType.ListBegin, 0)
		dataList.Add(LispDataType.Text, resStr.StringResult)
		dataList.Add(LispDataType.Int32, resInt.Value)
		dataList.Add(LispDataType.Angle, resAng.Value)
		dataList.Add(LispDataType.Point3d, resPt.Value)
		dataList.Add(LispDataType.ListEnd, 0)
		' add the Variable to AutoCad
		acedPutSym(LispVarName, DirectCast(dataList, ResultBuffer).UnmanagedObject)
		' get the Lisp variable from AutoCAD
		Dim rb1114c As ResultBuffer = GetLispSym(LispVarName)
		If rb1114c IsNot Nothing Then
			For Each val As TypedValue In DirectCast(rb1114c, System.Collections.IEnumerable)
			Next
		End If
	End Sub
End Class
End Namespace
