Hi,
I have been folowing number of google links on this issue namely a shortcut for activating the Mid Between Two Points or M2P/MTP without success. So far aliasedit is of no use and there is no OSmode for Mid Between Two Points, likewise none for FROM.
Regards,
Nicolas.
Hi,
Thanks for the links. Still, I have been unable to do this seemingly easy task of creating a shortcut key as in cui|keyboard shortcuts there are
1. shortcut keys
2. Temporary Override keys
And when I right click shortcut keys, I get "New Temporary Override"
Also, there is no M2P or MTP in all commands list.
Regards,
Nicolas
M2P or MTP is a command modifier not a command in of of itself. That's why if you were to type MTP at the command line (assuming it was a command) AutoCAD returns "Unknown command".
MTP
Locates the midpoint between two points.
Hi,
Thank for responding. With that in mind, what should I do?
I know it's no command and for this reason we can't create an alias for it. By the way a three-character long command modifier can be considered an alias by itself. The fact that so many has succeed in applying m2p to F1 or other keyboard key means that there is a possibility of making thing even easier than Shift-Right Click and choosing M2P, especially that I use this command numerous times daily.
Regards,
Nicolas.
How about doing it with a macro assigned to a button?
Shift key + right mouse button won't work for you? It is pretty quick to execute. Or type MTP at the command line after starting a command.
Heres a toolbar version
MiddlePt [_Button("Middle 2 pts","RCDATA_16_OSNMID","RCDATA_32_OSNMID")]MTP
Hi Bigal,
I believe I am missing something ... I can't get it working. Here is a pic of my CUI as I created a command mp, paste your code and apply it to a toolbar called TNM.
Edited by nicolas
Wrong Pics
The Osnap Macro is just _MTP or _M2P
Here's a screenshot of the MTP button I added to my OSNAP toolbar.
