Don't put any dimensioning. For a quick location point draw a circle with its center point on the grid intersection for the nearest spot elevation you used in your calculations. The point at which the circle intersects the grid (between the two elevations you are working with) is where you insert your block (like the one I suggested). Then you can put your label (text) next to it. I'd instruct you about using attributes with a block but you seem to be struggling at the moment so we will steer clear of that. After you have inserted the block erase the circle. To check a dimension between two objects you can use the DISTANCE command (DI for short) and remember to use your OSnaps to make accurate picks. You are familiar with OSnaps right?
Not sure about the "0"? In this exercise your new spot elevations should be going on a specific layer (probably called out in your project instructions) and not on layer "0".
  • Replies 27
  • ReMark
    13
  • bracken2
    13
  • eldon
    2
yes, I', familiar with it, I keep working on it.
ok I start over, on the part where I put my spot elevation,(xxx) it says to put the 3 x, on the lower-left corner, but my question is do they go on the left side or right, or bottom,
  ReMark said:
Why don't you find the thread that has the images of this project included in it and take a look.
Never mind. I found it for you. Personally I don't think it matters where it goes.
http://www.cadtutor.net/forum/showthread.php?57959-Civil-drafting-school-project-help/page3
here a update on my new drawing,I put the xxx, at the right side of the X
Civil drafting 05404100.dwgFetching info...
I'm not on my CAD computer at the moment but when I have the opportunity I'll take a look. Did you click on the link to the other thread I posted?
Yes, but they are different, I have been looking at the one you posted
I don't think it's going to matter much. As long as the location of the symbol is correct relative to the grid and as long as you have the correct spot elevation assigned then I think you'll be fine.
