12 hours ago, Dien nguyen said:
I used this lisp to convert the color of the object to true color. Now I'm looking for a way to change the color of all layers from RGB to TrueColor. I consulted Lee-Mac's website but I still don't know how to use it. Please help.
Try this:
(defun c:foo ( / accm c ly nm)
    (setq accm
        (vla-getinterfaceobject (vlax-get-acad-object)
            (strcat "AutoCAD.AcCmColor." (substr (getvar 'ACADVER) 1 2))
    (while
        (setq ly (tblnext "layer" (not ly)))
        (and
            (wcmatch (setq nm (cdr (assoc 2 ly))) "~*|*")
            (setq c (cdr (assoc 62 ly)))
                (vla-put-ColorIndex accm c)
                (entmod
                    (append
                        (entget (tblobjname "layer" nm))
                        (list
                            (cons 420
                                (apply 'LM:RGB->True
                                    (mapcar
                                        'vlax-get-property
                                        (list accm accm accm)
                                        '(red green blue)
    (vlax-release-object accm)
;; RGB -> True - Lee Mac 2011
;; Args: r,g,b - Red,Green,Blue values
(defun LM:RGB->True (r g b)
       (lsh (fix r) 16)
       (lsh (fix g) 8)
       (fix b)
Edited by Jonathan Handojo
10 hours ago, Jonathan Handojo said:
Try this:
    (setq accm
    (while
        (and
                (entmod
                    (append
                        (list
                            (cons 420
                                    (mapcar
                                        'vlax-get-property
                                        '(red green blue)
       (lsh (fix r) 16)
       (lsh (fix g) 8)
       (fix b)
Thanks Jonathan, it works for me.
