Jonathan Handojo Posted March 4 Posted March 4 (edited) 12 hours ago, Dien nguyen said: I used this lisp to convert the color of the object to true color. Now I'm looking for a way to change the color of all layers from RGB to TrueColor. I consulted Lee-Mac's website but I still don't know how to use it. Please help. Try this: (defun c:foo ( / accm c ly nm) (setq accm (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar 'ACADVER) 1 2)) ) ) (while (setq ly (tblnext "layer" (not ly))) (and (wcmatch (setq nm (cdr (assoc 2 ly))) "~*|*") (setq c (cdr (assoc 62 ly))) (progn (vla-put-ColorIndex accm c) (entmod (append (entget (tblobjname "layer" nm)) (list (cons 420 (apply 'LM:RGB->True (mapcar 'vlax-get-property (list accm accm accm) '(red green blue) ) ) ) ) ) ) ) ) ) (vlax-release-object accm) (princ) ) ;; RGB -> True - Lee Mac 2011 ;; Args: r,g,b - Red,Green,Blue values (defun LM:RGB->True (r g b) (+ (lsh (fix r) 16) (lsh (fix g) 8) (fix b) ) ) Edited March 4 by Jonathan Handojo 1 Quote
Dien nguyen Posted March 4 Posted March 4 10 hours ago, Jonathan Handojo said: Try this: (defun c:foo ( / accm c ly nm) (setq accm (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar 'ACADVER) 1 2)) ) ) (while (setq ly (tblnext "layer" (not ly))) (and (wcmatch (setq nm (cdr (assoc 2 ly))) "~*|*") (setq c (cdr (assoc 62 ly))) (progn (vla-put-ColorIndex accm c) (entmod (append (entget (tblobjname "layer" nm)) (list (cons 420 (apply 'LM:RGB->True (mapcar 'vlax-get-property (list accm accm accm) '(red green blue) ) ) ) ) ) ) ) ) ) (vlax-release-object accm) (princ) ) ;; RGB -> True - Lee Mac 2011 ;; Args: r,g,b - Red,Green,Blue values (defun LM:RGB->True (r g b) (+ (lsh (fix r) 16) (lsh (fix g) 8) (fix b) ) ) Thanks Jonathan, it works for me. Quote
