whiteangel10 Posted January 4, 2012 Posted January 4, 2012 I have some .dwg files; when the defpoints layer it's activated and a draw something, after that i cannot select what i've drawn; the grips doesn't appear when I want to select the drawing. Thanks! Quote
DANIEL Posted January 4, 2012 Posted January 4, 2012 make a new layer for your viewports and set it not to plot, def points is not meant for this. Quote
CyberAngel Posted January 4, 2012 Posted January 4, 2012 Is it a clipped viewport? If so, the polyline border may be on a frozen layer. Quote
whiteangel10 Posted January 5, 2012 Author Posted January 5, 2012 @Daniel, I know that, but i want to know why I cannot select viewports or any lines drawn on defpoints layer. @ReMark&CyberAngel, the layer isn't frozen. Quote
DANIEL Posted January 5, 2012 Posted January 5, 2012 can you post the file so one of us can take a look at it for you? Quote
ReMark Posted January 5, 2012 Posted January 5, 2012 Rename the Defpoints layer to something else like "Junk". Now, try to select an object on that layer. Does it work or not? Quote
whiteangel10 Posted January 6, 2012 Author Posted January 6, 2012 Thank you Remark, it works! How can I make a layer like that one so I cannot select without changing the name?! Quote
whiteangel10 Posted January 6, 2012 Author Posted January 6, 2012 I know that but I don't understand why that error appears in defpoints layer. Quote
ReMark Posted January 6, 2012 Posted January 6, 2012 It is not an error. You are using an "old" trick for putting objects on a layer that does not print. That is now considered to be a bad practice although some will argue otherwise. Do you even know what the Defpoints layer is used for by AutoCAD? Do you know why it is created by AutoCAD in the first place? My advice is STOP drawing on the defpoints layer. Do so at your own risk. Quote
