pumplady Posted October 20, 2008 Posted October 20, 2008 I am having trouble with a linetype error. I keep getting a bad definition error when trying to load the linetype. I am using AutoCAD Civil 3D 2009. Occasionally I can get the linetype to load correctly, but it takes a lot of doing, and the next time I try the same solution, it doesn't work. Below is the linetype I am trying to load. FENCELINE3,Fenceline chain ----X-----X----X-----X----X--- A,.25,-.0005,["X",ROMANS,S=.1,R=0.0,x=-.1,Y=-0.05],-.0005,.25 Any help would be appreciated. Thanks, Mendy Quote
lpseifert Posted October 20, 2008 Posted October 20, 2008 Be sure the text style named Romans is defined before loading the linetype. Also, I think there should be a * before FENCELINE3 in the first line. Quote
pumplady Posted October 21, 2008 Author Posted October 21, 2008 Thanks, sometimes it is the smallest things that get ya. I had the wrong text defined. Thanks again. Quote
