razie1 Posted December 29, 2011 Posted December 29, 2011 hiya im quite new to inventor and need a little help. im trying to build a motor bike frame and don't know which would be the best way to do it, should i do it all in 3d sketch or in parts with 2d? thanks in advance Quote
JD Mather Posted December 29, 2011 Posted December 29, 2011 I would do 2D sketches of the side and top views. Then 3D Sketch of interscetion between the 2 2D sketches. Then use Frame Generator. Quote
razie1 Posted December 30, 2011 Author Posted December 30, 2011 Thanks for that, Ive have completed the sketches now but i have run in to a problem with frame generator. when i try to miter or notch it won't let me select merged frames. am i doing somthing wrong? Quote
JD Mather Posted December 30, 2011 Posted December 30, 2011 You can only use the miter or notch tools with straight tubes. To trim a curved tube or a straight tube with a curved tube - Edit the part in the context of the assembly. Copy Object as surface the face of the tube to use for trimming. Split Part or Sculpt Remove the tube to be trimmed with the copied surface body. Attach a couple of parts and assembly here if you can't figure it out. Quote
