Designer Posted October 20, 2008 Posted October 20, 2008 Which hardware do you recomend to have to make a faster render? I made a render last night in revit 2009 it took me 9 hours and 45 minutes. Quote
tzframpton Posted October 20, 2008 Posted October 20, 2008 Which hardware do you recomend to have to make a faster render? I made a render last night in revit 2009 it took me 9 hours and 45 minutes. Multi-core processors, the biggest Workstation level graphics accelerator your budget will allow, and max out the RAM. All of this, of course, should be running on a motherboard that supports the highest bus speeds you can buy. Basically, a whole new computer for the best results and it will definitely cost. I don't know if this is just for personal use, or for business. Quote
Designer Posted October 20, 2008 Author Posted October 20, 2008 I am thinking in buying one of these: LG S510-X-CP20P Asus G71V Toshiba Satellite A300-1ID can anyone give me opinions of them? Quote
tzframpton Posted October 20, 2008 Posted October 20, 2008 Those are gaming laptops. I would get a workstation. Hop over to http://www.hp.com or http://www.dell.com and see what they have over there. Quote
Designer Posted October 20, 2008 Author Posted October 20, 2008 Which laptops do you recomend, but not too much expensive. Quote
tzframpton Posted October 20, 2008 Posted October 20, 2008 Here's a good one: http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/321957-321957-64295-3740645-3329741-3784202.html Quote
Designer Posted October 20, 2008 Author Posted October 20, 2008 Isn`t this Toshiba Satellite A300-1ID a good one? Nice RAM, nice graphic and processor Quote
tzframpton Posted October 20, 2008 Posted October 20, 2008 I can't find a good Spec sheet of the Toshiba. Can you link me somewhere so I can take a look? Even Toshiba's site seems to be down. Quote
Designer Posted October 20, 2008 Author Posted October 20, 2008 Here it is, in my language Processador tipo : Processador Intel® Core™2 Duo T9400 velocidade de relógio : 2.53 GHz Front Side Bus : 1066 MHz cache de n Quote
tzframpton Posted October 20, 2008 Posted October 20, 2008 Once again, it is a "gaming" computer. It will still work though. all of them will but I was trying to help you with the absolute best option. Quote
jpms24 Posted December 7, 2008 Posted December 7, 2008 what's the difference between workstation and pc, what would be the best choice in workstation?? Quote
JRevit Posted December 7, 2008 Posted December 7, 2008 i render both at home and work, and the 2 pc's are opposite. work pc amd 5600+ x2 ati x1950 pro 512mb 2gb ram home pc e6750 intel 8800 GT 512mb 4gb ram guess what, the work pc renders quicker! quite considerably to. Quote
