Lee Mac Posted February 28, 2013 Posted February 28, 2013 darkorange said: thanks lee mac i got it i created a new template with my linetypes loaded No problem Though, if you are using a template you may as well have the layers already created in the template Quote
darkorange Posted February 28, 2013 Posted February 28, 2013 true i did that too!i was not remember that too.keep good work thx Quote
marko_ribar Posted February 28, 2013 Posted February 28, 2013 darkorange said: no they aren't!its a new drawing only load Bylayer,Byblock and continuous....isn't possible to load then automatic?i will try to search for that! (defun c:loadltypes ( / fn f rl ltname ltypes ) (setq fn (open (setq f (findfile "acadiso.lin")) "r")) (while (setq rl (read-line fn)) (if (eq "*" (substr rl 1 1)) (setq ltname (substr rl 1 (vl-string-position (ascii ",") rl)))) (if ltname (progn (setq ltname (vl-string-left-trim "*" ltname)) (setq ltypes (cons ltname ltypes)) ) ) ) (foreach ln ltypes (command "_.linetype" "l" f "" "s" ln "") ) (command "_.linetype" "s" "ByLayer" "") (princ) ) Quote
darkorange Posted February 28, 2013 Posted February 28, 2013 thx marko_ribar i solved the problem with a new template! Quote
Richard Lim Posted February 19, 2019 Posted February 19, 2019 On 12/20/2011 at 10:31 AM, pBe said: (defun c:UA () (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") '(2 . "001_Urban_Areas") '(70 . 0) '(62 . 25) '(6 . "Continuous") ) ) (princ) ) (defun c:UA () (command "_.Layer" "_Make" "001_Urban_Areas" "_Color" "25" "" "LType" "Continuous" "" "") (princ) ) Hi, im new here, can someone help me on this routine, it works by it says unknown command. basicly i got this from someone and i just added for layer description. Richard (DEFUN C:ANNO (/ CME LYR RGM) (SETQ CME (GETVAR "CMDECHO")) (SETQ LYR (GETVAR "CLAYER")) (SETQ RGM (GETVAR "REGENMODE")) (SETVAR "CMDECHO" 0) (SETVAR "REGENMODE" 0) ;;;; ANNOTATION******************************************************************************************************************** (COMMAND "LAYER" "MAKE" "A-ANNO-DIMS" "COLOR" "1" "" "L" "CONTINUOUS" "" "LW" "0.13" "" "D" "ANNOTATION: DIMENSIONS" "A-ANNO-DIMS" "" "") (COMMAND "LAYER" "MAKE" "A-ANNO-REFR" "COLOR" "2" "" "L" "CONTINUOUS" "" "LW" "0.25" "" "D" "ANNOTATION: REFERENCE TAGS" "A-ANNO-REFR" "" "") (COMMAND "LAYER" "MAKE" "A-ANNO-NOTE" "COLOR" "2" "" "L" "CONTINUOUS" "" "LW" "0.25" "" "D" "ANNOTATION: NOTES" "A-ANNO-NOTE" "" "") (COMMAND "LAYER" "MAKE" "A-ANNO-ARRW" "COLOR" "1" "" "L" "CONTINUOUS" "" "LW" "0.13" "" "D" "ANNOTATION: ARROWS" "A-ANNO-ARRW" "" "") ;;;;; (SETVAR "CMDECHO" CME) (SETVAR "CLAYER" LYR) (SETVAR "REGENMODE" RGM) (PRINC)) (PRINC "\nCOMMAND: ANNO") Expand Quote
BIGAL Posted February 19, 2019 Posted February 19, 2019 I tried removing the last double quote quote seemed to work then the extra was calling the layer command again. You can keep going with the layer command so it could all be one command line. A neater way is to use a list so can have as many layers as you like ("A-ANNO-DIMS" "1" "CONTINUOUS" "0.13" "ANNOTATION: DIMENSIONS"...........) Then just make each layer in the list. Quote
MAzri Posted January 6, 2023 Posted January 6, 2023 On 12/29/2011 at 12:23 AM, Lee Mac said: An Introduction to... Creating Layers Using Entmake Reference for Layer DXF Group Codes Happy coding, Lee Expand After 12 years, still helping a lot of beginner out there. Many thanks LM! Quote
