BIGAL Posted January 15 Posted January 15 Is this you ? I posted a solution for testing. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/table-export-for-multiple-drawings-to-excel/td-p/8886650 Quote
bonehead_96 Posted January 16 Posted January 16 Hello All, First thanks for any and all help anyone can provide. I am working a lisp to export/copy table data from 100's of drawings to csv files for each drawing and have the csv file the same name as the drawing. I started with a lisp called "Exp_Tbl.lsp" I found on another site and modified it a little to extract the table data and create a csv file with the name of the drawing it was extracted from, however, I'm struggling with how the data is written in the csv, I can't seem to get the results I need. I know where in the lisp that needs tweaking, but I just can't seem to find the right combination. I have attached "Desired results", "actual results", "EEX.lsp" (my version) and drawings with the table. Thanks again for any help Quote
bonehead_96 Posted January 16 Posted January 16 Thanks, BigAl, I have seen this Lisp, the issue I have with this particular one is that I have over 100 drawings on many projects that I will need to run this routine on, so creating a script with the path, dwg number, and csv file name for each would defeat the purpose of using a lisp. 1. The lisp I attached to my original post (EEX.lsp) will open all the drawings in a selected directory and extract table data to individual CSV files, which is what I need. 2. The issue I'm having with the EEX.lsp is that the table data is not compiled correctly, its close, but not correct. 3. I believe the issue is in the area shown in the attachment, I just can't seem to get that correctly written. Thanks again for your response problem area.txtFetching info... Quote
BIGAL Posted January 16 Posted January 16 Can you give the code a test please yes its manual pick but I will add the find all tables in a dwg without user input. So you also want an individual Excel for each dwg that can be done also. I am asking for comments about output. I wrote the current version as a modification of the original export a table. Its pretty easy to write a script that will open a dwg and run a lisp, make the Excel save it then close Excel. Quote
bonehead_96 Posted January 17 Posted January 17 I'm sorry BIGAL, I totally misunderstood. Tried it, I believe it works in that the information is copied from all the drawings to a single CSV. It appears that in the description the comma creates a new column. I've attached the script, lisp, dwgs and csv files. I do appreciate your help Thanks you CTE.SCRFetching info... CTE.LSPFetching info... 2-EG-AG-1002-H-ET_DWG-001.dwgFetching info... 2-EG-AG-1002-H-ET_DWG-002.dwgFetching info... 2-EG-AG-1002-H-ET_DWG-003.dwgFetching info... CustomTableExport.csvFetching info... Quote
