bartymic Posted December 18, 2011 Share Posted December 18, 2011 hi, i have two viewports in layout and i do not know how to set up correct properties to each one. thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 18, 2011 Share Posted December 18, 2011 What "properties" are you referring to? I can think of two: scale and display (locked/unlocked). What else are you thinking of? Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 18, 2011 Author Share Posted December 18, 2011 i defined in layer properties manager VP Plot Style for one viewport and i do not know how to defined different VP Plot Style for second one. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 18, 2011 Share Posted December 18, 2011 Have you looked at your Help file re: Override Layer Properties in Viewports? Quote Link to comment Share on other sites More sharing options...
rickh Posted December 18, 2011 Share Posted December 18, 2011 This is from the help files: On the layout tab, double-click inside a viewport to make it current. Click Home tab Layers panel Layer Properties In the Layer Properties Manager, select the global properties to override in the VP Color, VP Linetype, VP Lineweight, and VP Plot Style columns. The assumption is that you are using Named Plot Styles. My only guess is that you set the layer override without actually being in a viewport. If that's true, just double click inside one to get the layer overrides for that viewport alone. Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 18, 2011 Author Share Posted December 18, 2011 thank you both Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 21, 2011 Author Share Posted December 21, 2011 ok, actually i could override the layer. but i do not know how to turn off one layer, if i do it by turning off ON tab (lighting bulb), layers ,,disappear,, in both viewports. i hope that caused by the fact that ON tab is not for VP. unfortunately, i did not find correct way. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 21, 2011 Share Posted December 21, 2011 Try opening your Layer Properties Manager and look for the column with the heading VP Freeze. You have to be in the viewport you want to freeze a layer in when you use this method. Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 21, 2011 Author Share Posted December 21, 2011 i freezed the layer and it is still visible, i also hope that i use correct viewport Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 22, 2011 Share Posted December 22, 2011 Since I don't have your drawing in front of me, and have no idea what you froze, it is difficult for me to know what you did or did not do. Sorry. Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 22, 2011 Author Share Posted December 22, 2011 the main idea how to make layer invisible in viewport is to put VP freeze layer to blue color Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 22, 2011 Share Posted December 22, 2011 Are you asking me, telling me or just thinking out loud? Have you tried looking at your AutoCAD Help file for further information? This is the topic heading: Freeze Specified Layers in a Layout Viewport Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 22, 2011 Author Share Posted December 22, 2011 thanks a lot, help is useful, hovewer anywhere i make a mistake Quote Link to comment Share on other sites More sharing options...
bartymic Posted December 22, 2011 Author Share Posted December 22, 2011 it works in layer control. in layer properties manager not. thanks again for your patience. Quote Link to comment Share on other sites More sharing options...
