  anishtain4 said:
I didn't get it, this is a response to alan or my post? :D
whichever it is it hits error: no function definition: VLAX-ENAME->VLA-OBJECT
I'm not much into Vlisp yet to debug it :D
Ooops sorry about that
You AND Alanjt :)
Add this line:
(defun c:IOI (/ AT:TriangleArea ss i ent obj dst off)
[color=blue][b](vl-load-com)[/b][/color]
[color=#0000ff]....[/color]
  pBe said:
It can be done, BUT i will code it to work only with closed polylines. I believe you know what will happen if its not specially with a 2 vertices polyline.
Your orignal code shows exclusive selection for ""LWPOLYLINE" BUT we can manage that. ;)
(defun c:oi (/ e etyp pto)
(vl-load-com)
;;; Lee Mac ;;;
(defun LM:ListClockwise-p (lst)
(minusp
(apply '+
(mapcar
(function
(lambda (a b)
(- (* (car b) (cadr a)) (* (car a) (cadr b)))
lst
(cons (last lst) lst)
(if (setq e (ssget "_+.:S:E" '((0 . "*LINE"))))
(if (not dist)
(setq dist 1.00)
(setq dist (cond
((getreal
(strcat "\nEnter Distance <"
(rtos (abs dist) 2 2)
((abs dist))
(setq e (ssname e 0)
etyp (cdr (assoc 0 (entget e)))
(cond
((and
(eq etyp "LWPOLYLINE")
(> (cdr (assoc 90 (entget e))) 2)
(vla-put-closed (vlax-ename->vla-object e) :vlax-true)
(setq dist
(if (LM:ListClockwise-p
(mapcar 'cdr
(vl-remove-if-not
'(lambda (x)
(= (car x) 10)
(entget e)
dist
(* dist -1.0)
(while
(not (vl-catch-all-error-p
(vl-catch-all-apply
'vla-offset
(list (vlax-ename->vla-object e) dist)
(setq e (entlast))
((eq etyp "LINE")
(if (not rep)
(setq rep 1)
(initget 6)
(setq d dist
rep (cond ((getint
(strcat "\nNumber of Offset <"
(itoa rep)
(rep)
pto (getpoint "\nGetpoint Side to offset:")
(repeat rep
(command "._offset" d e pto nil)
(setq d (+ d dist))
)(princ)
For one thing , you're on it
Hello pBe,
Could you modify this code so it allows selecting many object lines ,arcs splines and polyline and offseting them simultanously.
This was my 'Offset Inside' program:
[color=GREEN];; Offset Inside  -  Lee Mac  -  www.lee-mac.com[/color]
[color=GREEN];; Offsets a set of objects by a specified distance to the inside.[/color]
([color=BLUE]defun[/color] c:OffInside ( [color=BLUE]/[/color] acsel pos )
   ([color=BLUE]if[/color]
       ([color=BLUE]and[/color]
           ([color=BLUE]setq[/color] *dist*
               ([color=BLUE]cond[/color]
                   (   ([color=BLUE]getdist[/color]
                           ([color=BLUE]strcat[/color] [color=MAROON]"\nOffset Distance"[/color]
                               ([color=BLUE]if[/color] *dist* ([color=BLUE]strcat[/color] [color=MAROON]" <"[/color] ([color=BLUE]rtos[/color] *dist*) [color=MAROON]">: "[/color]) [color=MAROON]": "[/color])
                   (   *dist*   )
           ([color=BLUE]ssget[/color]
                   (-4 . [color=MAROON]"<OR"[/color])
                       (0 . [color=MAROON]"CIRCLE,ARC,ELLIPSE"[/color])
                       (-4 . [color=MAROON]"<AND"[/color])
                           (0 . [color=MAROON]"LWPOLYLINE,SPLINE"[/color]) (-4 . [color=MAROON]"&="[/color]) (70 . 1)
                       (-4 . [color=MAROON]"AND>"[/color])
                           (0 . [color=MAROON]"POLYLINE"[/color]) (-4 . [color=MAROON]"&="[/color]) (70 . 1)
                           (-4 . [color=MAROON]"<NOT"[/color])
                               (-4 . [color=MAROON]"&"[/color]) (70 . 120)
                           (-4 . [color=MAROON]"NOT>"[/color])
                   (-4 . [color=MAROON]"OR>"[/color])
       ([color=BLUE]progn[/color]
           ([color=BLUE]vlax-for[/color] obj
               ([color=BLUE]setq[/color] acsel
                   ([color=BLUE]vla-get-activeselectionset[/color]
                       ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
               ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-offset[/color]
                   ([color=BLUE]list[/color] obj
                               ([color=BLUE]setq[/color] pos ([color=BLUE]vl-position[/color] ([color=BLUE]vla-get-objectname[/color] obj) '([color=MAROON]"AcDbPolyline"[/color] [color=MAROON]"AcDb2dPolyline"[/color])))
                               (LM:ListClockwise-p (LM:GroupByNum ([color=BLUE]vlax-get[/color] obj 'coordinates) ([color=BLUE]+[/color] pos 2)))
                           *dist* ([color=BLUE]-[/color] *dist*)
           ([color=BLUE]vla-delete[/color] acsel)
   ([color=BLUE]princ[/color])
[color=GREEN];; List Clockwise-p  -  Lee Mac[/color]
[color=GREEN];; Returns T if the point list is clockwise oriented[/color]
([color=BLUE]defun[/color] LM:ListClockwise-p ( lst )
   ([color=BLUE]minusp[/color]
       ([color=BLUE]apply[/color] '[color=BLUE]+[/color]
           ([color=BLUE]mapcar[/color]
               ([color=BLUE]function[/color]
                   ([color=BLUE]lambda[/color] ( a b )
                       ([color=BLUE]-[/color] ([color=BLUE]*[/color] ([color=BLUE]car[/color] b) ([color=BLUE]cadr[/color] a)) ([color=BLUE]*[/color] ([color=BLUE]car[/color] a) ([color=BLUE]cadr[/color] b)))
               lst ([color=BLUE]cons[/color] ([color=BLUE]last[/color] lst) lst)
[color=GREEN];; Group by Number  -  Lee Mac[/color]
[color=GREEN];; Groups a list into a list of lists, each of length 'n'[/color]
([color=BLUE]defun[/color] LM:GroupByNum ( l n [color=BLUE]/[/color] r)
   ([color=BLUE]if[/color] l
           ([color=BLUE]reverse[/color] ([color=BLUE]repeat[/color] n ([color=BLUE]setq[/color] r ([color=BLUE]cons[/color] ([color=BLUE]car[/color] l) r) l ([color=BLUE]cdr[/color] l)) r))
           (LM:GroupByNum l n)
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
You AND Alanjt :)
Add this line:
I believe something is wrong, it only offsets five time outside, I rather the #6 post yet
Just as I suspected. you have a "seemingly closed" pline
use this on your pline:
 (defun c:test ()
  (cdr (assoc 70 (entget (car (entsel)))))
command: test
select objects:
the result will be one of these bit values
0
1
4
128
129
132
133
Like most of the codes on this thread, inifinite will only works with flg 1
But no worries, we can still accomodate your request by testing if first and lastpoint is equal
See updated code
HTH
I remember this one Lee. AAMOF thats where i got the idea for the code posted at post #9 :)
It was useful to someone then at least :P
It's all 0, for all the cases I use
As I said your #6 is good, maybe I modify it after I read the lisp bible. I can manage my things for now. I wrote a lisp which do offset five time on an arbitrary side, and changed your code to offset only inside. I get the mixed when I have enough knowledge myself.
 ;; Infinite Offset Inward (well, not infinite, but as much as possible, given the offset increment
 ;; Alan J. Thompson, 12.19.11
 (vl-load-com)
 (defun AT:TriangleArea (a b c)
   ;; Returns area of three provided points
   ;; If returned value is negative, last point (c) exists on right side of a-b vector
   ;; Alan J. Thompson, 06.09.10
   (/ (- (* (- (car b) (car a)) (- (cadr c) (cadr a)))
         (* (- (cadr b) (cadr a)) (- (car c) (car a)))
      2.
 (initget 6)
 (if (and (setq *IOI:Inc* (cond ((getdist (strcat "\nSpecify inward offset increment"
                                                  (if (numberp *IOI:Inc*)
                                                    (strcat " <" (rtos *IOI:Inc*) ">: ")
                                (*IOI:Inc*)
          (setq ss (ssget "_:L"
                          '((-4 . "<OR")
                            (0 . "ARC,CIRCLE")
                            (-4 . "<AND")
                            (0 . "LWPOLYLINE")
                            (-4 . "&=")
                            (70 . 1)
                            (-4 . "AND>")
                            (-4 . "<AND")
                            (0 . "POLYLINE")
                            (-4 . "&=")
                            (70 . 1)
                            (-4 . "<NOT")
                            (-4 . "&")
                            (70 . 120)
                            (-4 . "NOT>")
                            (-4 . "AND>")
                            (-4 . "OR>")
     (setq ent (ssname ss (setq i (1- i)))
           obj (vlax-ename->vla-object ent)
           dst (if (and (wcmatch (vla-get-objectname obj) "*Polyline")
                        (minusp (AT:TriangleArea
                                  (vlax-curve-getPointAtParam ent 0)
                                  (vlax-curve-getPointAtParam ent 1)
                                  (vlax-curve-getPointAtParam ent 2)
                 *IOI:Inc*
                 (- *IOI:Inc*)
     (while
       (not
         (vl-catch-all-error-p (setq off (vl-catch-all-apply 'vlax-invoke (list obj 'Offset dst))))
        (setq obj (car off))
Ok Anishtain4, its your call :)
I would suggest you use the code at post#19 where you can select multiple objects , if the its a 1 segment pline it will prompt you to pick the side then proceed on the next one. we can tweak it to prompt for number of repeat like the one on post #6 >
Cheers
It's #6, #9 closes the polyline which is not something I want, I don't use multilines because I have to adjust all of my drawings in regard to others, so I have to do them one by one. I just changed the ssget line to "_:L" so if I missed the first click I won't have to repeat the command from the first.
Thanks
FWIW #19 [updated code] doesnt close the polyline as long as first and end point is the same.
Anyhoo, you are Welcome anishtain4, at least you have a couple of codes to study [Alanjt/EP/Lee Mac/pBe/tharwat]
Have fun ;)
In my experience it closes all of my polylines and then start to offsetting. Yeppppp, I have a lot of codes to study, and thank you all
Hello pBe,
Could you modify your code so it allows selecting many object lines ,arcs splines and polyline and offseting them simultanously.
  fathihvac said:
Hello pBe,
Try this first:
Lee Mac or Alanjt this thread :)
Hello pBe,
On my ie i can't see the number of post could you it for me ,Thanks
  fathihvac said:
Hello pBe,
Upgrade your IE to the latest version.
  • 1 month later...
 (vl-load-com)
;;; Lee Mac ;;;
   (minusp
     (apply '+
     (mapcar
       (function
  (lambda (a b)
       lst
     (if (not dist)
(setq dist 1.00)
     (setq dist (cond
    ((getreal
    ((abs dist))
     (cond
((and
 (setq dist
       (mapcar 'cdr
        (vl-remove-if-not
   '(lambda (x)
      (= (car x) 10)
   (entget e)
   dist
   (* dist -1.0)
 (while
   (vl-catch-all-apply
     'vla-offset
    (setq e (entlast))
((eq etyp "LINE")
 (if (not rep)
   (setq rep 1)
 (initget 6)
 (setq d   dist
       rep (cond ((getint
       (itoa rep)
   (rep)
 (repeat rep
   (setq d (+ d dist))
   )(princ)
Hi pBe,
Hope you remember me, this Lisp is working with Line only. I don't want that Infinite Mode, if I want to select any PLine (or both "Line" and "Pline") then how is this possible? Thanks.
Welcome to the forum Saqib_theleo,
Looks like you heed my advice and posted your request where you got the orignal code.
Now. what exactly do you need? What you're asking is not that difficult at all, only, there are a couple of codes (AlanjT/LM/Tharwat/.... ) posted on this thread, i suggest you try them all first and see what code is better suited for your needs (you know what they say about re-inventing the wheel) [bTW: who are these people they cal "THEY" ? is there a building out there with a room that says "THEY" on the door? :lol:]
Or maybe, you need an entirely different routine. :)
