Hi
I'm trying to write a script which would enable me to redefine a block, save and close the drawing. I would like to run it on multiple drawings. I have managed to write a script which does redefine the block but it stops and either I get "Unit-scaling inserted database..." message or it starts a new command..... ("Command: 1.000000")
I did not get the script to save the changes or close the drawings. Any help would me very much appreciated.
Below you will find the script file
(command "._insert" "Drawing Sheet A1=U:/27979/Config/DWGSheets/test/Drawing Sheet A1.dwg" 0.0
_units 1.00
_basepoint 0,0
_scale 1.0
_rotate 0.0
qsave
close
Edited by SLW210
apologies :oops:, I did wasn't aware of code posting guidelines. Please find below coding with the code tags
_units 1.00
_basepoint 0,0
_scale 1.0
_rotate 0.0
qsave
close
thanks,
Arek
Your mixing lisp and script togther
insert U:/27979/Config/DWGSheets/test/Drawing Sheet A1.dwg
0.0
1.00
0,0
1.0
0.0
qsave
close
Thanks Bigal:D,
I modified your code a little however after I specify the rotation angle 0.0, I need to cancel modifing the attributes in the title block. How do I do it? At the moment the script is changing my attributes to "_.save", "_Y" etc....:( Any help would be very much appreciated!
._insert "Drawing Sheet A1=U:/27979/Config/DWGSheets/test/Drawing Sheet A1.dwg" 0.0
1.00
1.00
0.0
;here I need to cancel revising the attributes within title block
_.save
_Y
_.close
Create a script, test on one file. If it works, use autodesk scriptpro (search online for it) to apply it to a number of drawings
I have managed to make the script working!!:):D It's my first one, so I'm even more happy!
Just thought will share this script which works. The empty lines are "enter" for the attributes to remain unchanged. And will use ScriptPro to apply it to multiple drawings.
1.00
1.00
0.0
_.erase
_L
_.zoom
_E
_.qsave
_.close
_N
I was going to post often you need extra lines as if you pressed the enter button, the other way is to uses spaces as the same thing but can be on the same line makes the script a bit easier to read sometimes if its all 1 line.
Try it with yours 2nd line would be next drawing.
open dwg1 ._insert "Drawing Sheet A1=U:/27979/Config/DWGSheets/test/Drawing Sheet A1.dwg" 0.0 1 1 0.0       etc
open dwg2 ._insert "Drawing Sheet A1=U:/27979/Config/DWGSheets/test/Drawing Sheet A1.dwg" 0.0 1 1 0.0
