sanderson Posted December 9, 2011 Share Posted December 9, 2011 Hi: I am using SolidWorks 2DEditor, and need to add some text from code to the lower-right corner of the drawing. The snag seems to be in obtaining the system variables EXTMIN and EXTMAX. Any thoughts?? Thanks in advance for the help! Sub AddFooter() Dim txtfooterString As String txtfooterString = "n:\temp\footerstring.txt" Dim footerString As String Open txtfooterString For Input As #1 Do While Not EOF(1) Line Input #1, footerString Loop Close #1 MsgBox ("footerString: " & footerString) Dim minExt As Object Dim maxExt As Object Set minExt = doc.GetVariable("EXTMIN") Set maxExt = doc.GetVariable("EXTMAX") MsgBox (CStr(maxExt) & ", " & CStr(minExt)) Dim lr(0 To 1) As Double lr(0) = maxExt(0) lr(1) = minExt(1) Dim height As Double height = 0.1 Dim textObj As Text Set textObj = doc.AddText(footerString, lr, height) textObj.Update End Sub Quote Link to comment Share on other sites More sharing options...
sanderson Posted December 12, 2011 Author Share Posted December 12, 2011 Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long) Sub Main() Dim doc As DWGeditor.Document Set doc = DWGeditor.ActiveDocument Sleep (5) AddFooter Sleep (5) Dim lyt As Layout Set lyt = doc.ActiveLayout lyt.PlotType = vicExtents lyt.PlotRotation = vic90degrees lyt.StyleSheet = "monochrome.ctb" lyt.PaperUnits = vicInches lyt.StandardScale = vicToFit lyt.ScaleLineweights = False lyt.CenterPlot = True doc.Regen Set lyt = Nothing doc.PrintDrawing End Sub Sub AddFooter() Dim doc As DWGeditor.Document Set doc = DWGeditor.ActiveDocument Dim txtfooterString As String txtfooterString = "n:\temp\footerstring.txt" Dim footerString As String Open txtfooterString For Input As #1 Do While Not EOF(1) Line Input #1, footerString Loop Close #1 Debug.Print ("footerString: " & footerString) Dim minExt As DWGeditor.Point Dim maxExt As DWGeditor.Point Set minExt = doc.GetVariable("EXTMIN") Set maxExt = doc.GetVariable("EXTMAX") Dim sc As Double sc = doc.GetVariable("DIMSCALE") Dim ip As Object Set ip = Library.CreatePoint(0.987 * maxExt.x, minExt.y, 0) Dim height As Double height = 0.0625 * sc Dim textObj As DWGeditor.Text Set textObj = doc.ModelSpace.AddText(footerString, ip, height) textObj.HorizontalAlignment = vicHorizontalAlignmentRight textObj.Update End Sub Quote Link to comment Share on other sites More sharing options...
