sham Posted December 8, 2011 Posted December 8, 2011 can any help to solve this problem. Normally dimension in engineering value come like this 14'4" but my come 4"14' how to solve this thanks a lot Quote
Dadgad Posted December 8, 2011 Posted December 8, 2011 Have you defined your dimension style properly in the dim style manager? On the Primary Units tab of the MODIFY DIMENSIONAL STYLE dialog box you should select ENGINEERING on the linear dimensions FORMAT field. Quote
sham Posted December 9, 2011 Author Posted December 9, 2011 thanks for this. but i have tried this but this cannot help me what i need is my engineering dimension is like "4'14 insead of 14'4" Quote
Dadgad Posted December 9, 2011 Posted December 9, 2011 thanks for this. but i have tried this but this cannot help me what i need is my engineering dimension is like "4'14 insead of 14'4" Post a small DWG file in which you are having this problem? It should be very simple to sort out. Have you inadvertently, or otherwise, entered a TEXT OVERRIDE value into the dimension? Quote
SLW210 Posted December 9, 2011 Posted December 9, 2011 Please post the file. Select your diminsion, properties, text and check Text rotation and Text view direction. Quote
sham Posted December 21, 2011 Author Posted December 21, 2011 Thank you very much for your help Quote
