Quattro_Trip Posted December 6, 2011 Share Posted December 6, 2011 Hey guys, Good day. first time im using scriptpro. I am doing about 400plus drawings and I need help on Batch freezing of rev clouds and triangles and Printing to pdf using Scriptpro. Do you have a script that runs in scriptpro that i can use? Autocad abs 2006 Layer to freeze "*REV*" Print to pdf and I'll just rename the pdfs. thanks a bunch Quote Link to comment Share on other sites More sharing options...
Quattro_Trip Posted December 6, 2011 Author Share Posted December 6, 2011 or is there a Lisp command that I can use and just call it in an *.scr file? thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 7, 2011 Share Posted December 7, 2011 Only problem is the pdf bit and the only answer seems to be to use DWG to PDF you can save a pdf name this way as part of your script, just call a defun to return pdf name. (pdfname) -la F *REV* Plot .... then plot stuff with pdfname returned Close Open next repeat above Quote Link to comment Share on other sites More sharing options...
