ReMark Posted December 3, 2011 Posted December 3, 2011 Strangely enough I find that I cannot upload a 128.8KB file something I'm sure I've done a few times or more in the past. Did I maybe reach some max limit of file uploads? If so, how do I delete previous files that I have uploaded to CT to make room for the new upload? Thanks. Quote
Jack_O'neill Posted December 3, 2011 Posted December 3, 2011 Did you try a different file? Maybe there's something hinkey with that one. Quote
ReMark Posted December 3, 2011 Author Posted December 3, 2011 Had trouble as well trying to upload a JPG file to another thread. I can Select the file but cannot upload it. Weird. Quote
Jack_O'neill Posted December 4, 2011 Posted December 4, 2011 I had a similar problem one day, but it went away. Never thought about it again till I saw your post. Quote
CADTutor Posted December 4, 2011 Posted December 4, 2011 Strangely enough I find that I cannot upload a 128.8KB file something I'm sure I've done a few times or more in the past. Did I maybe reach some max limit of file uploads? If so, how do I delete previous files that I have uploaded to CT to make room for the new upload? Thanks. That's odd, there doesn't seem to be a problem with file upload and you're well within your quota. What type of file are you uploading? Quote
ReMark Posted December 4, 2011 Author Posted December 4, 2011 The first file was an AutoCAD DWG (saved in 2000 file format). Size: 128.8KB I'll try again this morning. Maybe it had something to do with my Internet connection. Thanks. Quote
Jack_O'neill Posted December 4, 2011 Posted December 4, 2011 The first file was an AutoCAD DWG (saved in 2000 file format). Size: 128.8KB I'll try again this morning. Maybe it had something to do with my Internet connection. Thanks. Are you using satellite internet? I am and have all sorts of trouble if it's raining, or snowing, or really cloudy, or a flock of geese fly over....it's better than dial up but if i could get cable or dsl out here in bojacks I'd drop it in a heartbeat. Quote
ReMark Posted December 4, 2011 Author Posted December 4, 2011 Satellite? Yes. Sunny, cold, dry morning. I was just able to upload, by mistake, the same drawing saved in 2007 file format yet I cannot upload the drawing in 2000 file format. 2007 file size = 71KB. 2000 file size = 137KB (up 9KB since I first saved it). The damn thing just won't upload. I just checked some of the files I've uploaded in the past and found several that were larger in size so I have no idea why I can't get this one to load. Frustrating. This is so weird. I got it to work but I first had to insert another file before I could insert the one I really wanted then I had to delete the first one. Argh!!!!!!!!!!!!!!!!!!!!!!! Quote
CADTutor Posted December 5, 2011 Posted December 5, 2011 Well, I can't explain that. I don't *think* the problem is at this end - there's no obvious reason why you shouldn't be able to upload any DWG file under 1MB. I haven't tested every version but there's no record of a problem with any previous version. Sorry Quote
ReMark Posted December 16, 2011 Author Posted December 16, 2011 The problem resurfaced again today. Could not upload a simple PNG file via normal means. Had to resort to using the Basic Uploader. Quote
ReMark Posted December 30, 2011 Author Posted December 30, 2011 Every image I uploaded today was done using the Basic Uploader. Not sure why the other method no longer works. Running Win7 Ultimate 64-bit at the moment. Oh well, at least the old method works. Quote
ReMark Posted January 3, 2012 Author Posted January 3, 2012 No I haven't. Good idea though. Will try then post results. Quote
