Glen1980 Posted December 2, 2011 Posted December 2, 2011 Im in the West Midlands mate......yourself? I'm in Hertfordshire near Stansted Airport. Personally Dan if you've taken half an hour to do a bathroom layout within half an hour on your first go I'd say that's pretty good. You'll get quicker everytime you use it, plus there is a Sketchup forum within the CADtutor forums. Do the tutorials as well, they do help. Especially learn how to create components, that stops all of your different elements from interfering with each other when you do start producing complex models. Quote
Dana W Posted December 2, 2011 Posted December 2, 2011 Drill bit will open the ports up wider' date=' make it anything you want. edit--just be careful if you drill out the choke point in the swivel, they made the wall pretty thin there to prevent what I just descibed. May have to do some improvisation with the plumbing if you have an adjustible shower head.[/quote']You got that right. I did drill an adjustable one out and ended up with a combination water jet saw and Gattling gun. Quote
PotGuy Posted May 16, 2013 Posted May 16, 2013 I'm in Hertfordshire near Stansted Airport. Personally Dan if you've taken half an hour to do a bathroom layout within half an hour on your first go I'd say that's pretty good. You'll get quicker everytime you use it, plus there is a Sketchup forum within the CADtutor forums. Do the tutorials as well, they do help. Especially learn how to create components, that stops all of your different elements from interfering with each other when you do start producing complex models. Whoo, another Herts CADDY! Quote
welldriller Posted May 17, 2013 Posted May 17, 2013 Plumber you have already been give excellent advise but thought i would ad my two cents worth. 1 - this is not a professional drawing (not that good really) 2 - It sole purpose is to show you what can be done in Autocad LT Quote
Tiger Posted May 17, 2013 Posted May 17, 2013 The OP is from 2011 so I hope Dan the Plumber have chosen a cad-system by now Quote
welldriller Posted May 17, 2013 Posted May 17, 2013 The OP is from 2011 so I hope Dan the Plumber have chosen a cad-system by now If the OP is as slow and inattentive as i am he may not Thanks for waking me up Quote
