Hi again,
Was just wondering if you can manipulate a Autocad Block Reference in any way in Inventor 2009 Pro or 2012 Pro. Was looking to a simple way of converting them to .ipt's. The attached image is in general what I am working with.
Any input or suggestions would be greatly appreciated.
Thanks
BillB
File>Open
Options>Import
Post an example here (dwg - not image).
After trying a few different things, I guess there's really not a way to "Reference Blocks" to make into .ipt's, at least I haven't found it yet
BillB
Why would anyone create 3D as wireframe?
Simply explode the block before importing into Inventor.
Hi again J.D.,,,,, thanks for the reply. Yeah, there lies the problem,, this is a machine with several different parts that was designed in Cadkey 3D several years back. I converted over to Autocad to be able to manipulate in some fashion, So now I think that they will want us to build this machine and I was trying different things to save a little time. I will try your suggestion and explode the block before importing. Just wondering,, do you think IV2012 Pro with 2Dto3D Convert would be helpful in this situation?
Thanks again J.D.
BillB
The version of Inventor is irrelevant.
