CyberAngel Posted November 28, 2011 Posted November 28, 2011 (edited) I need to use detail callouts on a regular basis. They all have to look the same, even though some appear in paper space and some in model space. I've gone to a user block. The attribute style has a width factor of 1.25. I overrode it in the block and changed it to 1.00. When I draw a multileader with this style, the block has text with width of 1.25. AutoCAD has overridden my override. On a similar note, when I change the multileader definition from the default _DetCallout to the user-defined DetCallout (note the underline), the existing multileaders don't update, and I can't figure out how to make them update. Is it a bug, a quirk, or something else? Does it really matter what you call it if they never fix it? Edited November 29, 2011 by CyberAngel Quote
SLW210 Posted November 29, 2011 Posted November 29, 2011 What is your detail callout? I use a custom dynamic block for mine, but there is one on the Tool Palette Annotation tab. I don't use multileaders since I save down to 2004. Quote
CyberAngel Posted November 29, 2011 Author Posted November 29, 2011 My block looks a lot like the default block. The font is different, and the linework has a bit of width, but it's still a divided circle with a number and a sheet. Quote
