ketxu Posted November 23, 2011 Posted November 23, 2011 Please, please help me to drawing this with entmake or some command (Polygon, Circle, Pline or Arc). I've try with command, but i'm very very chicken in geometry ang bugle, i've problem with calculate coordinates, so it become a big problem... (all dimension and two small circle+3/4 circle in center of bolt are not need,i just add to described. Input is D) Thanks all for help Quote
ketxu Posted November 23, 2011 Author Posted November 23, 2011 I'm trying to put in into one lisp code with DCL belong to D, or eventhough drawing it manualy then makeEntmake, then scale it as a block.. But, as i mention, i'm very very chicken in geometry Quote
ketxu Posted November 24, 2011 Author Posted November 24, 2011 So, could you help me how to entmake an arc through 3 point ? or make a same shape Pline ? Quote
Lee Mac Posted November 24, 2011 Posted November 24, 2011 (edited) So, could you help me how to entmake an arc through 3 point? Here are my functions relating to 3-Point Arcs/Circles: [color=GREEN];; 3-Point Arc - Lee Mac[/color] [color=GREEN];; Returns the Center, Start/End Angle, Radius of the[/color] [color=GREEN];; Arc defined by three supplied points.[/color] ([color=BLUE]defun[/color] LM:3PArc ( p1 p2 p3 [color=BLUE]/[/color] cn m1 m2 ) ([color=BLUE]setq[/color] m1 (mid p1 p2) m2 (mid p2 p3) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] cn ([color=BLUE]inters[/color] m1 ([color=BLUE]polar[/color] m1 ([color=BLUE]+[/color] ([color=BLUE]angle[/color] p1 p2) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.)) 1.0) m2 ([color=BLUE]polar[/color] m2 ([color=BLUE]+[/color] ([color=BLUE]angle[/color] p2 p3) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.)) 1.0) [color=BLUE]nil[/color] ) ) ([color=BLUE]append[/color] ([color=BLUE]list[/color] cn) ([color=BLUE]if[/color] (LM:Clockwise-p p1 p2 p3) ([color=BLUE]list[/color] ([color=BLUE]angle[/color] cn p3) ([color=BLUE]angle[/color] cn p1)) ([color=BLUE]list[/color] ([color=BLUE]angle[/color] cn p1) ([color=BLUE]angle[/color] cn p3)) ) ([color=BLUE]list[/color] ([color=BLUE]distance[/color] cn p1)) ) ) ) [color=GREEN];; 3-Point Circle - Lee Mac[/color] [color=GREEN];; Returns the Center and Radius of the Circle defined[/color] [color=GREEN];; by three supplied points.[/color] ([color=BLUE]defun[/color] LM:3PCircle ( p1 p2 p3 [color=BLUE]/[/color] cn m1 m2 ) ([color=BLUE]setq[/color] m1 (mid p1 p2) m2 (mid p2 p3) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] cn ([color=BLUE]inters[/color] m1 ([color=BLUE]polar[/color] m1 ([color=BLUE]+[/color] ([color=BLUE]angle[/color] p1 p2) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.)) 1.0) m2 ([color=BLUE]polar[/color] m2 ([color=BLUE]+[/color] ([color=BLUE]angle[/color] p2 p3) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.)) 1.0) [color=BLUE]nil[/color] ) ) ([color=BLUE]list[/color] cn ([color=BLUE]distance[/color] cn p1)) ) ) [color=GREEN];; Midpoint - Lee Mac[/color] [color=GREEN];; Returns the midpoint of two points[/color] ([color=BLUE]defun[/color] mid ( a b ) ([color=BLUE]mapcar[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]/[/color] ([color=BLUE]+[/color] a b) 2.0))) a b) ) [color=GREEN];; Clockwise-p - Lee Mac[/color] [color=GREEN];; Returns T if p1,p2,p3 are clockwise oriented[/color] ([color=BLUE]defun[/color] LM:Clockwise-p ( p1 p2 p3 ) ([color=BLUE]<[/color] ([color=BLUE]*[/color] ([color=BLUE]-[/color] ([color=BLUE]car[/color] p2) ([color=BLUE]car[/color] p1)) ([color=BLUE]-[/color] ([color=BLUE]cadr[/color] p3) ([color=BLUE]cadr[/color] p1))) ([color=BLUE]*[/color] ([color=BLUE]-[/color] ([color=BLUE]cadr[/color] p2) ([color=BLUE]cadr[/color] p1)) ([color=BLUE]-[/color] ([color=BLUE]car[/color] p3) ([color=BLUE]car[/color] p1))) ) ) Test Functions: [color=GREEN];; Test Functions[/color] ([color=BLUE]defun[/color] c:3PArc ( [color=BLUE]/[/color] p1 p2 p3 lst ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] p1 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 1st Point: "[/color])) ([color=BLUE]setq[/color] p2 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 2nd Point: "[/color] p1)) ([color=BLUE]setq[/color] p3 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 3rd Point: "[/color] p2)) ([color=BLUE]setq[/color] lst (LM:3PArc ([color=BLUE]trans[/color] p1 1 0) ([color=BLUE]trans[/color] p2 1 0) ([color=BLUE]trans[/color] p3 1 0))) ) ([color=BLUE]entmake[/color] ([color=BLUE]append[/color] '((0 . [color=MAROON]"ARC"[/color])) ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 50 51 40) lst))) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]defun[/color] c:3PCircle ( [color=BLUE]/[/color] p1 p2 p3 lst ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] p1 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 1st Point: "[/color])) ([color=BLUE]setq[/color] p2 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 2nd Point: "[/color] p1)) ([color=BLUE]setq[/color] p3 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 3rd Point: "[/color] p2)) ([color=BLUE]setq[/color] lst (LM:3PCircle ([color=BLUE]trans[/color] p1 1 0) ([color=BLUE]trans[/color] p2 1 0) ([color=BLUE]trans[/color] p3 1 0))) ) ([color=BLUE]entmake[/color] ([color=BLUE]append[/color] '((0 . [color=MAROON]"CIRCLE"[/color])) ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 40) lst))) ) ([color=BLUE]princ[/color]) ) Dynamic Test Functions: [color=GREEN];; Dynamic Test Functions[/color] ([color=BLUE]defun[/color] c:3PGrArc ( [color=BLUE]/[/color] p1 p2 p3 lst arc ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] p1 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 1st Point: "[/color])) ([color=BLUE]setq[/color] p2 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 2nd Point: "[/color] p1)) ([color=BLUE]setq[/color] p3 ([color=BLUE]cadr[/color] ([color=BLUE]grread[/color] [color=BLUE]t[/color] 13 0))) ([color=BLUE]setq[/color] lst (LM:3PArc ([color=BLUE]setq[/color] p1 ([color=BLUE]trans[/color] p1 1 0)) ([color=BLUE]setq[/color] p2 ([color=BLUE]trans[/color] p2 1 0)) ([color=BLUE]trans[/color] p3 1 0))) ([color=BLUE]setq[/color] arc ([color=BLUE]entmakex[/color] ([color=BLUE]append[/color] '((0 . [color=MAROON]"ARC"[/color])) ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 50 51 40) lst)))) ([color=BLUE]setq[/color] arc ([color=BLUE]list[/color] ([color=BLUE]cons[/color] -1 arc))) ([color=BLUE]princ[/color] [color=MAROON]"\nSpecify 3rd Point: "[/color]) ) ([color=BLUE]while[/color] ([color=BLUE]=[/color] 5 ([color=BLUE]car[/color] ([color=BLUE]setq[/color] gr ([color=BLUE]grread[/color] [color=BLUE]t[/color] 13 0)))) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] lst (LM:3PArc p1 p2 ([color=BLUE]trans[/color] ([color=BLUE]cadr[/color] gr) 1 0))) ([color=BLUE]entmod[/color] ([color=BLUE]append[/color] arc ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 50 51 40) lst))) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]defun[/color] c:3PGrCircle ( [color=BLUE]/[/color] p1 p2 p3 lst cir ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] p1 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 1st Point: "[/color])) ([color=BLUE]setq[/color] p2 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 2nd Point: "[/color] p1)) ([color=BLUE]setq[/color] p3 ([color=BLUE]cadr[/color] ([color=BLUE]grread[/color] [color=BLUE]t[/color] 13 0))) ([color=BLUE]setq[/color] lst (LM:3PCircle ([color=BLUE]setq[/color] p1 ([color=BLUE]trans[/color] p1 1 0)) ([color=BLUE]setq[/color] p2 ([color=BLUE]trans[/color] p2 1 0)) ([color=BLUE]trans[/color] p3 1 0))) ([color=BLUE]setq[/color] cir ([color=BLUE]entmakex[/color] ([color=BLUE]append[/color] '((0 . [color=MAROON]"CIRCLE"[/color])) ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 40) lst)))) ([color=BLUE]setq[/color] cir ([color=BLUE]list[/color] ([color=BLUE]cons[/color] -1 cir))) ([color=BLUE]princ[/color] [color=MAROON]"\nSpecify 3rd Point: "[/color]) ) ([color=BLUE]while[/color] ([color=BLUE]=[/color] 5 ([color=BLUE]car[/color] ([color=BLUE]setq[/color] gr ([color=BLUE]grread[/color] [color=BLUE]t[/color] 13 0)))) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] lst (LM:3PCircle p1 p2 ([color=BLUE]trans[/color] ([color=BLUE]cadr[/color] gr) 1 0))) ([color=BLUE]entmod[/color] ([color=BLUE]append[/color] cir ([color=BLUE]mapcar[/color] '[color=BLUE]cons[/color] '(10 40) lst))) ) ) ) ([color=BLUE]princ[/color]) ) Finally, a 3-Point 'PolyArc': [color=GREEN];; 3-Point PolyArc[/color] ([color=BLUE]defun[/color] c:3PPolyArc ( [color=BLUE]/[/color] p1 p2 p3 lst ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] p1 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 1st Point: "[/color])) ([color=BLUE]setq[/color] p2 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 2nd Point: "[/color] p1)) ([color=BLUE]setq[/color] p3 ([color=BLUE]getpoint[/color] [color=MAROON]"\nSpecify 3rd Point: "[/color] p2)) ([color=BLUE]setq[/color] lst (LM:3PArc ([color=BLUE]trans[/color] p1 1 0) ([color=BLUE]trans[/color] p2 1 0) ([color=BLUE]trans[/color] p3 1 0))) ([color=BLUE]setq[/color] lst ([color=BLUE]apply[/color] 'LM:Arc->Bulge lst)) ) ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"LWPOLYLINE"[/color]) '(100 . [color=MAROON]"AcDbEntity"[/color]) '(100 . [color=MAROON]"AcDbPolyline"[/color]) '(90 . 2) '(70 . 0) ([color=BLUE]cons[/color] 10 ([color=BLUE]car[/color] lst)) ([color=BLUE]cons[/color] 42 ([color=BLUE]caddr[/color] lst)) ([color=BLUE]cons[/color] 10 ([color=BLUE]cadr[/color] lst)) ) ) ) ([color=BLUE]princ[/color]) ) [color=GREEN];; Arc to Bulge - Lee Mac 2011[/color] [color=GREEN];; cen - Centre[/color] [color=GREEN];; ang1 - Start Angle[/color] [color=GREEN];; ang2 - End Angle[/color] [color=GREEN];; rad - Radius[/color] [color=GREEN];; Returns: (<vertex> <vertex> <bulge>)[/color] ([color=BLUE]defun[/color] LM:Arc->Bulge ( cen ang1 ang2 rad ) ([color=BLUE]list[/color] ([color=BLUE]polar[/color] cen ang1 rad) ([color=BLUE]polar[/color] cen ang2 rad) ( ([color=BLUE]lambda[/color] ( a ) ([color=BLUE]/[/color] ([color=BLUE]sin[/color] a) ([color=BLUE]cos[/color] a))) ([color=BLUE]/[/color] ([color=BLUE]rem[/color] ([color=BLUE]+[/color] [color=BLUE]pi[/color] [color=BLUE]pi[/color] ([color=BLUE]-[/color] ang2 ang1)) ([color=BLUE]+[/color] [color=BLUE]pi[/color] [color=BLUE]pi[/color])) 4.)) ) ) Arc->Bulge from my set of Bulge Conversion Functions. Edited November 26, 2011 by Lee Mac Updated functions, added 3PPolyArc Quote
FELIXJM Posted November 24, 2011 Posted November 24, 2011 Use the program below to create the ENTMAKE of what is drawn. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (DEFUN C:CRIAENTMAKE () (SETQ ARQUIVO "C:\\$ENTMAKE.TXT") (SETQ ARQ (OPEN ARQUIVO "w")) ; ;;;CRIA BLOCOS... ; (WRITE-LINE "(SETQ MBLOCO \"NOMEDOBLOCO\")" ARQ) (WRITE-LINE "(IF (AND (NOT (FINDFILE (STRCAT MBLOCO \".DWG\"))) (NOT (TBLSEARCH \"BLOCK\" MBLOCO) ))" ARQ) (WRITE-LINE " (PROGN" ARQ) (WRITE-LINE " (ENTMAKE (list (cons 0 \"BLOCK\") (cons 2 MBLOCO) (cons 8 \"0\") (cons 10 (list 0 0 0)) (cons 70 2) ) ) ;(CONS 70 2)=BLOCO COM ATRIBUTOS" ARQ) (SETQ ENT (ENTNEXT)) (WHILE ENT (SETQ LIS (ENTGET ENT)) (PRINC "\n" ARQ) (PRINC " (ENTMAKE (LIST " ARQ) (SETQ NN 0) (REPEAT (LENGTH LIS) (SETQ CCC (NTH NN LIS)) (IF (AND (/= (CAR CCC) -1) (/= (CAR CCC) 5) (/= (CAR CCC) 330) (/= (CAR CCC) 410) ) (PROGN (PRINC " '" ARQ) (PRIN1 CCC ARQ) ) ) (SETQ NN (+ NN 1)) ) (PRINC " )" ARQ) (PRINC " )" ARQ) (SETQ ENT (ENTNEXT ENT)) ) (WRITE-LINE " (ENTMAKE (list (cons 0 \"ENDBLK\")))" ARQ) (WRITE-LINE " )" ARQ) (WRITE-LINE ") " ARQ) (WRITE-LINE "; " ARQ) (CLOSE ARQ) (ALERT "*** BLOCO CRIADO COM SUCESSO! ***") (COMMAND "NOTEPAD" ARQUIVO) ; (PRINC) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (PROMPT "\n==> CRIAENTMAKE <==") (PRINC) OK? Quote
ketxu Posted November 25, 2011 Author Posted November 25, 2011 Thanks Lee, i'll try to solve my problem with yours function, and i think it'll be okey. @Felixjm : thank u, i'm finding the solution with some of calculate geometry ^^ Thank all for help, i love all of you Quote
fuccaro Posted November 26, 2011 Posted November 26, 2011 Ketxu After you made the block, probable you will think to make it dynamic. Also the same block could contain the front, the top and the side view of the nut -and of course a visibility state to select the desired one. Quote
ketxu Posted November 26, 2011 Author Posted November 26, 2011 KetxuAfter you made the block, probable you will think to make it dynamic. Also the same block could contain the front, the top and the side view of the nut -and of course a visibility state to select the desired one. @fuccaro : I see, i will draw a block by hand, but first thing, i want to make it by some of code entmake ^^ @Lee : I will apply your code to make arc now , but, if you already have solution for make same Pline through 3 Point, let me know please ^^, or i will try to find out in the near future ^^ Thank you again Quote
Lee Mac Posted November 26, 2011 Posted November 26, 2011 @Lee : I will apply your code to make arc now , but, if you already have solution for make same Pline through 3 Point, let me know please ^^, or i will try to find out in the near future ^^ Thank you again Ketxu, You could use the 'Arc->Bulge' function from my Bulge Conversion functions to convert the return of the '3PArc' function to units suitable for use with LWPolylines. Shame I've not been consistent with the order of my arguments/returns. I fail. Quote
ketxu Posted November 26, 2011 Author Posted November 26, 2011 LeeMac, i've just came back home from site.. Oh, i don't know what to say... Just thank you very very much i love you ^^ Quote
marko_ribar Posted November 26, 2011 Posted November 26, 2011 (edited) ketxu, see if this drawing is OK, and if it is use this code to make lisp for entmakex drawn objects : (defun c:drawit ( / ss ssh acsel ssn k ent entl entll entlll f) (vl-load-com) (if (setq ssh (ssget "X" '((0 . "HATCH")))) (progn (vlax-for obj (setq acsel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (vla-put-associativehatch obj :vlax-false) ) (vla-delete acsel) )) (setq ss (ssget "X")) (setq ssn (sslength ss)) (setq f (open "C:/mklist.lsp" "w")) (setq k -1) (repeat ssn (setq k (1+ k)) (setq ent (ssname ss k)) (setq entl (entget ent)) (foreach x entl (if (and (/= (cdr (assoc 0 entl)) "HATCH") (/= (car x) -1) (/= (car x) 1) (/= (car x) 2) (/= (car x) 5) (/= (car x) (/= (car x) 102) (/= (car x) 330) (/= (car x) 360)) (setq entll (cons x entll)) ) (if (and (= (cdr (assoc 0 entl)) "HATCH") (/= (car x) -1) (/= (car x) 5) (/= (car x) (/= (car x) 102) (/= (car x) 330) (/= (car x) 360)) (setq entll (cons x entll)) ) ) (setq entll (reverse entll)) (setq entll (list (list 'quote entll))) (setq entlll (cons 'entmakex entll)) (print entlll f) (setq entll nil) (setq entlll nil) ) (close f) (princ) ) See attached *.dwg... Regards, M.R. Drawing-ketxu.dwg Model-ketxu.dwg Edited November 27, 2011 by marko_ribar dwg corrected - added model Quote
marko_ribar Posted November 27, 2011 Posted November 27, 2011 Updated and corrected *.dwg files - added model... M.R. Marko Ribar, d.i.a. (graduated engineer of architecture) Quote
Lee Mac Posted November 27, 2011 Posted November 27, 2011 LeeMac, i've just came back home from site.. Oh, i don't know what to say... Just thank you very very much i love you ^^ lol thanks Ketxu Quote
