fredrivard Posted November 22, 2011 Posted November 22, 2011 We would like to print a batch of files (up to 150-200) and be able to print over all DWG some information (Work Order number) that will be filled, or supplied by a text file (or somthing) else! I've check for a couples of hours now and did not find anything solid!! Any ideas anyone? I am not a CAD user, I am IT Staff!! Thank you!! Quote
DANIEL Posted November 22, 2011 Posted November 22, 2011 there are some options for you but it will require CAD work, for example, you could xref hte information in that way you can change the number on all 100-200 drawings once and then batch them .... it will require some descent CAD knowledge to accomplish your task regardless of how you approach it, if I understand you correctly. Quote
cadvision Posted November 22, 2011 Posted November 22, 2011 Have a look at RxHighlight R13 from Rasterex. www.rasterex.com It can batchprint and you can put water marks on. Quote
