mark3h Posted November 21, 2011 Share Posted November 21, 2011 Hi, im working on a project for university and it involves using .shp files, which i've imported fine, however the problem is that when i draw a line or polyline then save the file, close the program, reopen the file, the polyline appears for a split second while opening but then it disappears once the shape file loads. the polyline is on an active layer and i cant find it even when i untick the shape file in the task pane box so that there is nothing else in the drawing window. Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
mark3h Posted November 21, 2011 Author Share Posted November 21, 2011 it's ok actually, played about with it a bit and click "map layer" turns out because i had it off that was where the polylines were being drawn. Problem solved! Quote Link to comment Share on other sites More sharing options...
