19cruthik68 Posted November 20, 2011 Posted November 20, 2011 I just want to know how will I open a drawing file if its saved on an older version and I am using a latest version of autocad. thanks. Quote
stevsmith Posted November 20, 2011 Posted November 20, 2011 Newer releases open older files with no problems. Its only going to be an issue if you need to open a newer file with an older release of Autocad. Quote
CyberAngel Posted November 21, 2011 Posted November 21, 2011 You're going to have another issue when you save the drawing. If it was in 2007 format, your version (AutoCAD 2010) is going to save it in 2010 format. If the person who created it is still using AutoCAD 2007 and tries to open it, he'll have trouble. Quote
Jack_O'neill Posted November 21, 2011 Posted November 21, 2011 CyberAngel said: You're going to have another issue when you save the drawing. If it was in 2007 format, your version (AutoCAD 2010) is going to save it in 2010 format. If the person who created it is still using AutoCAD 2007 and tries to open it, he'll have trouble. Unless, you go to Tools, down to options, and click on "open and save". Then you can set your 2010 to always save to an older version. You can set this per profile, so if you have different profiles for different customers, you can set this if you have a customer that needs you to save down. Quote
BlackBox Posted November 21, 2011 Posted November 21, 2011 Jack_O said: You can set this per profile' date=' so if you have different profiles for different customers, you can set this if you have a customer that needs you to save down.[/quote'] Just for fun... You can also set this programmatically upon opening the drawing: (defun Set:SaveAsType ( / *error* _SaveAsType) ;; © RenderMan, 2011 (vl-load-com) (defun *error* (msg) (if f (close f)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** ")))) ; Fatal error, display it (princ)) (defun _SaveAsType (acApp typ s) (vla-put-saveastype (vla-get-opensave (vla-get-preferences acApp)) typ) (prompt (strcat "\n** Save As format = " s " ** "))) ((lambda (acApp titled dwg path / f l) (if (and (= 1 titled) (setq f (open (strcat path dwg) "r")) (setq l (read-line f)) (not (close f)) (not (setq f nil))) (cond ((vl-string-search "AC1014" l) (_SaveAsType acApp acR14_dwg "R14")) ((vl-string-search "AC1015" l) (_SaveAsType acApp ac2000_dwg "2000")) ((vl-string-search "AC1018" l) (_SaveAsType acApp ac2004_dwg "2004")) ((vl-string-search "AC1021" l) (_SaveAsType acApp ac2007_dwg "2007")) ((vl-string-search "AC1024" l) (_SaveAsType acApp ac2010_dwg "2010"))))) (vlax-get-acad-object) (getvar 'dwgtitled) (getvar 'dwgname) (getvar 'dwgprefix)) (*error* nil)) (Set:SaveAsType) ... Or you can use a custom command that will automagically save the drawing in the source drawing's file format: ** Original setting restored when done (defun c:SA+ () (c:SaveAs+)) (defun c:SaveAs+ (/ *error* _SaveAs+) ;; © RenderMan, 2011 (vl-load-com) (princ "\rSAVEAS+ ") (defun *error* (msg) (if f (close f)) (if oldTyp (vla-put-saveastype (vla-get-opensave (vla-get-preferences acApp)) oldTyp)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** ")))) ; Fatal error, display it (princ)) (defun _SaveAs+ (acApp typ s) ((lambda (acOSPrefs / oldTyp) (if (/= typ (setq oldTyp (vla-get-saveastype acOSPrefs))) (vla-put-saveastype acOSPrefs typ)) (vla-save (vla-get-activedocument acApp)) (prompt (strcat "\n\t\t\t** Drawing saved in " s " file format ** ")) (vla-put-saveastype acOSPrefs oldTyp) (setq oldTyp nil)) (vla-get-opensave (vla-get-preferences acApp)))) ((lambda (acApp titled dwg path / f l) (if (and (= 1 titled) (setq f (open (strcat path dwg) "r")) (setq l (read-line f)) (not (close f)) (not (setq f nil))) (cond ((vl-string-search "AC1014" l) (_SaveAs+ acApp acR14_dwg "R14")) ((vl-string-search "AC1015" l) (_SaveAs+ acApp ac2000_dwg "2000")) ((vl-string-search "AC1018" l) (_SaveAs+ acApp ac2004_dwg "2004")) ((vl-string-search "AC1021" l) (_SaveAs+ acApp ac2007_dwg "2007")) ((vl-string-search "AC1024" l) (_SaveAs+ acApp ac2010_dwg "2010")) ((prompt "\n** This file version is not supported ** "))) (prompt "\n** The drawing must be saved first ** "))) (vlax-get-acad-object) (getvar 'dwgtitled) (getvar 'dwgname) (getvar 'dwgprefix)) (*error* nil)) Quote
Tiger Posted November 22, 2011 Posted November 22, 2011 Good advice all around - and the cat skinning business goes on Quote
19cruthik68 Posted November 23, 2011 Author Posted November 23, 2011 what i mean is they gave me a drawing file which was saved to autocad2010. Now my Autocad2010 already uninstalled so i switched to Autocad2008. How can I open the files that they gave if they used 2010 and I am using 2008. thanks. Quote
dbroada Posted November 23, 2011 Posted November 23, 2011 you either need them to send it to you in 2007 format or get yourself the (free) Autodesk true convert program from their web site. Quote
BlackBox Posted November 23, 2011 Posted November 23, 2011 19cruthik68 said: what i mean is they gave me a drawing file which was saved to autocad2010. Now my Autocad2010 already uninstalled so i switched to Autocad2008. How can I open the files that they gave if they used 2010 and I am using 2008. thanks. This has already been answered.... Quote
dbroada Posted November 23, 2011 Posted November 23, 2011 RenderMan said: This has already been answered.... sorry, but how is that an answer? That link just takes you to a post that says you will have trouble. Quote
ReMark Posted November 23, 2011 Posted November 23, 2011 19cruthik68 said: what i mean is they gave me a drawing file which was saved to autocad2010. Now my Autocad2010 already uninstalled so i switched to Autocad2008. How can I open the files that they gave if they used 2010 and I am using 2008. thanks. Why would you UNINSTALL the newer program? Are you using a pirated copy of the software? Quote
Organic Posted November 23, 2011 Posted November 23, 2011 ReMark said: Why would you UNINSTALL the newer program? Are you using a pirated copy of the software? Perhaps he only had the trial or educational student version of 2010? Quote
BlackBox Posted November 23, 2011 Posted November 23, 2011 dbroada said: sorry, but how is that an answer? That link just takes you to a post that says you will have trouble. Seriously? The OP explicitly wants to open a newer file format drawing (2010) with an older version (2008 ), which will not work at all... *unless* the 2010 drawing was saved back to 2007 file format. Steve correctly points out (in the second post of this thread), that a newer release can open older file formats, however an older release cannot open newer file formats... AKA "Backward Compatibility." What is unclear? Quote
ReMark Posted November 23, 2011 Posted November 23, 2011 Dink87522 said: Perhaps he only had the trial or educational student version of 2010? I was thinking the same thing but then I saw that the OP had listed 2010 in his profile. Why bother to list a version you're only "testing" and not the version you're using? Quote
dbroada Posted November 23, 2011 Posted November 23, 2011 (edited) RenderMan said: Seriously? The OP explicitly wants to open a newer file format drawing (2010) with an older version (2008 ), which will not work at all... *unless* the 2010 drawing was saved back to 2007 file format. Steve correctly points out (in the second post of this thread), that a newer release can open older file formats, however an older release cannot open newer file formats... AKA "Backward Compatibility." What is unclear? Seriously. If there was no way to proceed I would agree but you can convert the newer file using AutoDesk software. That answers the question. Just pointing out that it can't be done doesn't. Edited November 23, 2011 by dbroada typo, said older - should have said newer Quote
BlackBox Posted November 23, 2011 Posted November 23, 2011 dbroada said: Seriously. If there was no way to proceed I would agree but you can convert the older file using AutoDesk software. That answers the question. Just pointing out that it can't be done doesn't. Unfortunately, my friend, converting the "older file" is not the plight of the OP... additionally, you're neglecting the context in which the question has been posed. Instead, the OP is trying to do exactly what is NOT possible - to open a newer drawing in an older version - without the file being converted back: 19cruthik68 said: what i mean is they gave me a drawing file which was saved to autocad2010. Now my Autocad2010 already uninstalled so i switched to Autocad2008. How can I open the files that they gave if they used 2010 and I am using 2008. thanks. Again, the OP's desired result is NOT possible with the applications specifically mentioned. Can another "Autodesk software" (or their former 2010 version) successfully resolve this matter, yes, certainly. Was that the question posed, however, no. Quote
Tiger Posted November 23, 2011 Posted November 23, 2011 Drop it guys. The OP have gotten all the info he needs to solve the current problem. Quote
BlackBox Posted November 23, 2011 Posted November 23, 2011 Tiger said: Drop it guys. The OP have gotten all the info he needs to solve the current problem. Sorry Tiger; Understood. Quote
ReMark Posted November 23, 2011 Posted November 23, 2011 Did anyone notice that the OP contradicted himself? Quote
Tiger Posted November 24, 2011 Posted November 24, 2011 ReMark said: Did anyone notice that the OP contradicted himself? Yep......... Quote
