First of all Hi to everyone!
When I use slice command in a 3D model, after separation into two parts, each part can't editable, you can only move them.
You can see in arrows on # 1 and # 2 3D model, but after using separate into it two parts by slice command , these arrows are disappeared.
How can I see arrows again to change dimensions of 3D model easily?
I hope that you can understand what I mean.
PHOTO LINK: http://imageshack.us/photo/my-images/171/sliceproblem.jpg/
Edited by sua
Why not post your image here?
Once you edit a 3D model with slice you lose the ability to use grips for modifications.
@SLW210
- Thanks for your answer. It's too disappointing! :(
BTW I have tried it but I can't upload from "insert image" , I don't know the reason why.
Select "Go Advanced" at lower right of reply box, then select "Manage attachments" to post image here.
You should use the _SOLIDEDIT command to make modifications, just no more using the grips.
A solid part can always be edited.
Not with the grips, that was the initial question.
While I was trying to edit my first message, it was disappeared. I don't know why had happened?
Anyway; I will post first message to here again:
(removed duplicate information/ Tiger)
Edited by Tiger
Removed duplicate information
There are restrictions set in place in this forum that limit users with less than 10 posts to post links. So when you edited the post, you added a link and that got your message moderated. I have now approved your post but I recommend that you read the posting guidelines here: How Do I Make A Post?
