scassidy15 Posted November 11, 2011 Posted November 11, 2011 Hi Guys, Hope I've got the right part of the forum for posting this thread... I am trying to import xyz data into AutoCAD using the multiple - point command, however when I paste the data as part of the command line it does not process the points but pastes the data as text into the model space. I hope I have explained this well enough, sorry if I have not. I have also tried using ascpoint.lsp however I struggled to get to grips with making it produce the points on screen. Thanks in advance. Quote
Lee Mac Posted November 11, 2011 Posted November 11, 2011 Hi scassidy, Welcome to CADTutor Perhaps my Point Manager program will help you. Quote
scassidy15 Posted November 11, 2011 Author Posted November 11, 2011 Lee Mac said: Hi scassidy, Welcome to CADTutor Perhaps my Point Manager program will help you. Thank you so much Lee Mac, that has solved my problem and far better than any other option i've tried. Thanks so much Quote
BIGAL Posted November 14, 2011 Posted November 14, 2011 Back to first post I have never had any problems pasting points to command line but I always paste from a txt file are you pasting excell columns ? Do they have more info than x,y,z line ptno,x,y,z,code will not work Quote
sanrajbhar Posted November 14, 2011 Posted November 14, 2011 while pasting (Ctl +V). Just focus the cursor in Command line. and press Ctrl +V. will definetly help. tried Out ! scassidy15 said: Hi Guys, Hope I've got the right part of the forum for posting this thread... I am trying to import xyz data into AutoCAD using the multiple - point command, however when I paste the data as part of the command line it does not process the points but pastes the data as text into the model space. I hope I have explained this well enough, sorry if I have not. I have also tried using ascpoint.lsp however I struggled to get to grips with making it produce the points on screen. Thanks in advance. Quote
