Greendamo Posted November 10, 2011 Share Posted November 10, 2011 Hi Ive modeled a handrail volute and i want to be able to print it off without the standard black background. The rendered image looks perfect with the black background but when i change it to white it makes the whole model white due to the reflection on it! Is there an easy way i can do this? any help would be appreciated. Thanks Damian Volute 3d Rendered.dwg Quote Link to comment Share on other sites More sharing options...
Murph_map Posted November 10, 2011 Share Posted November 10, 2011 Create a named view and set a background for that view, then render. Quote Link to comment Share on other sites More sharing options...
dynomyte2 Posted November 17, 2011 Share Posted November 17, 2011 From your file, you used the generic lights setting. Chang the setting to International light unit. I rendered using the setting mentioned and the result was ok. Quote Link to comment Share on other sites More sharing options...
Oppie Posted November 17, 2011 Share Posted November 17, 2011 I only changed the Sky to Off and typed the command background. I choose White. The backround always effects the model. Quote Link to comment Share on other sites More sharing options...
