soozyq Posted November 2, 2011 Posted November 2, 2011 Hi All, I am currently working in a profile where the end point is very close to a grid line and the two labels are overlapping. I would like to remove the end point label on the grid altogether. Is there a way of doing this? Would I need to do this on the alignment first? Thanks Sooz Quote
CyberAngel Posted November 7, 2011 Posted November 7, 2011 1) Hold down Ctrl key and click on end station label. That will let you select one label instead of the whole bunch. 2) Press Del key to delete that label. I believe that that will delete the label on the plan as well. Quote
soozyq Posted November 7, 2011 Author Posted November 7, 2011 1) Hold down Ctrl key and click on end station label. That will let you select one label instead of the whole bunch.2) Press Del key to delete that label. I believe that that will delete the label on the plan as well. Thanks CyberAngel. I tried that and this only seems to work on the plan rather than the profile. I'm using C3D 2009 if that makes any difference. Quote
CyberAngel Posted November 7, 2011 Posted November 7, 2011 Are we talking about a label on the grid itself, not on the profile? Can't you turn that off in the profile view style? Quote
