JackStone Posted October 30, 2011 Posted October 30, 2011 I have started to attempt to learn DCL and am currently using VLIDE as code editor. But when I write a DCL code and click "Format edit window" it returns an error: Error ocurredNot supported special symbol If I execute the code it runs just fine ("Preview DCL in editor" works, too), but I can't get it to organize my text. Doesn't it work at all or am I the only one having difficulties? I have been searching this since yesterday and have found not a single person mentioning it, which means either one of two things: no one has ever had this problem before or it is so simple to solve that no one ever needed to ask in internet forums. Hope I'm not asking a stupid question here This is an example of code I am trying to format (copied from a DCL tutorial by Jeff Sanders): EXAMPLE : dialog { label = "EXAMPLE.lsp"; : column { : boxed_column { label = "column 1"; : boxed_column { label = "column2"; } : boxed_column { label = "column 3"; } } ok_cancel; } } Thank you all in advance! Felipe Quote
MSasu Posted November 1, 2011 Posted November 1, 2011 From the help: If you select text to be formatted, the selection must contain valid AutoLISP expressions or the formatter will issue an error message. So, that error message is normal; the features work only with AutoLISP code. Will see that, after a while you will develop your own code formatting style and will not rely to the automated one anymore - me, for example, have never used it. Regards, Mircea Quote
