Ward Johnson Posted October 27, 2011 Posted October 27, 2011 I have just developed a problem where I can only snap to the origin regardless of where my cursor is. I have tried snapping to midpoints, endpoints, centers, etc. it always selects the origin. I even tried to cange the origin to a point I want to draw from, but it sends me right back to the original origin. I made no changes in the software setup - it started when I opened an existing drawing, and now it affects any drawing I start or open. I cannot get anything done. Quote
rkent Posted October 27, 2011 Posted October 27, 2011 More details... Are you using the line command or? So you have endpoint set as an osnap, pick the end of a line and instead your cursor is at 0,0? Any other details of what you are doing will help us with this. Quote
Ward Johnson Posted October 27, 2011 Author Posted October 27, 2011 I am using the line command and it appears that the beginning point of the line is offset from the point that I pick. I have checked and unchecked the "ignore z values" box and have tried several UCS commands without any results. The beginning point is offset in both the X and Y directions and drawing in the Z plane is not possible. Quote
rkent Posted October 27, 2011 Posted October 27, 2011 Sounds like SNAP is on, can you confirm that the SNAP button is toggled off? Also turn off OTRACK if it is on. Quote
