Architects sent some of the drawings and then i made x-ref in order to work but during work i face this message when i edit block...........
the block contains proxy objects and can not be edited in the block editor........???
how can i edit this type of block which contain this proxy object.....???;)
If you know which Autodesk product produced those proxy objects (and the message should tell you), you can download an object enabler from Autodesk.
http://www.autodesk.com/enablers
By the way, this information is easily found in the Help. I looked in the Index under Proxy Objects.
To put a constraint the objects are made proxy so that these are not changed by kind of mistakes. As CyberAngel said it can be easily enabled other than if any third party enabler is required. You can go with Autodesk enabler and in case find some difficulties share it in the forum so that some of our senior member can put more light on the topic.
-CNatka
