Elsa Posted October 26, 2011 Posted October 26, 2011 Hi, When I open a new template all the correct linetypes are there and the drawing works fine, I can purge and they are deleted if not in use. When I copy ANYTHING from one of my existing drawings which contains all these odd linetypes then they all appear in the new drawings and they will not purge. ANYTHING = Text, blocks, lines... etc. From reading about similar problems I think it has risesn from Binding/Inserting (I cant remember which one I used) of a Xref orignially from Microstation into a drawing I did about 3 months ago. The linetypes have just stuck around. Any suggestions on how to remove them? I have added a screen shot, hopefully it worked. Thank you! Quote
BIGAL Posted October 27, 2011 Posted October 27, 2011 Use Wblock to create a bit of the original drawing just cut a square of it out, a small dwg will be made so it can be posted. Quote
Elsa Posted October 27, 2011 Author Posted October 27, 2011 partial drawing.dwgFetching info... Other people in the office have opened the drawing on their computers and not incounted the linetypes... so they may not be there. Quote
