I'm working with C3D 2011.
I have a large number of EP shots along a roadway. I drew a lwpolyline connecting each point with a node snap (the entire line is at the elevation of the first point). I need each polyline vertex at the EP elevation.
Is there a way to convert my existing lwpolyline to a 3dpolyline AND have each vertex of the 3dpolyline inherit the elevation of the EP point/node that it was snapped to without redrawing the whole line using the 3dpoly command?
Thanks all
