liepa Posted October 20, 2011 Share Posted October 20, 2011 Hello everybody, 1) I have a solid with vertical walls. I need a solid, were some walls ar not vertical. So I need to move some vertices to the offset of top edge. Please, check a pic. (yellow edges have to be were are the red ones). I did it with construction lines, but I'm sure there is a more efficient way (with a command like offset). 2) Can I offset just a part of the solid at all? Thank you for any ideas Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 20, 2011 Share Posted October 20, 2011 solidedit taper faces or rotate face does basically the same thing. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 20, 2011 Share Posted October 20, 2011 _CHAMFER should work. Quote Link to comment Share on other sites More sharing options...
