Hi All - I am running Civil 3D 2010 and this morning I was working away as normal, until I went to use the delete key. I selected the line I wanted to delete, hit the delete key and nothing happened. I then started to notice other odd issues. For example I can no longer select an xref, right click, and open said xref. Also I cannot use ctrl-C to copy lines from one drawing to another. The most noticeable problem is that if I select a line and then hit any of the modify buttons (copy, move, mirror) the line is unselected and I am forced to reselect the items I want to modify.
While these are all small problems I do wonder if any of you know which setting I might have changed to cause these issues.
Thanks!
Try setting PICKADD=1. Test as needed. Report back.
Using the Pickfirst command and setting it to 1 solved all my problems! :)
THANKS!
