SuperCAD Posted October 14, 2011 Share Posted October 14, 2011 (edited) I've updated the video with caption to walk you through each step. Edited October 16, 2011 by SuperCAD Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 14, 2011 Share Posted October 14, 2011 Where is the video? Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted October 14, 2011 Author Share Posted October 14, 2011 (edited) I embedded the video in the post. Shows up on my end. Here's a direct link to it though: Edited October 17, 2011 by SuperCAD Quote Link to comment Share on other sites More sharing options...
fuccaro Posted October 15, 2011 Share Posted October 15, 2011 SuperCAD I enjoyed watching it. Nice touch to draw dimensions and use the dimensionlines as snap points when moving objects. I use to use point filters. I would have a question: You moved the threaded rod in the center of the nut. But how can you be sure that the threads will match? The image is not clear enough and I can not read in the command line the commands you used. Also the icons are unknown for me -I use only AutoCAD 2006 Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted October 15, 2011 Author Share Posted October 15, 2011 Some of the icons I have on my screen are custom for non-standard commands. Also, most of the buttons I use are arranged on a custom toolbar. I will post an updated video with either me speaking as I go, or I will add captions to explain what I am doing. I'm thinking the voice recording will be the way to go. As far as the threads matching, I used a 3/4-10 thread, so my thread pitch is exactly 0.10". The threaded part that I used to subtract from the nut was exactly 1" long, and the threaded rod was 2" long. I moved the threaded rod down 0.50", or 5 threads, to align both of them at their center points and made sure that the starting points of the helix were facing the same direction. When I cut the section through, it comes out dead on. I'm also going to see if I can increase the clarity of the video. A lot of the details will become more visible then. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted October 16, 2011 Author Share Posted October 16, 2011 The video has been replaced. You may need to hit the CC button to turn captions on. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 17, 2011 Share Posted October 17, 2011 Nevermind, No youtube at work. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted October 18, 2011 Author Share Posted October 18, 2011 Let me know what you think when you do get a chance to look at it. Quote Link to comment Share on other sites More sharing options...
baui25 Posted March 8, 2012 Share Posted March 8, 2012 sir kindly show the instructraction,,,step by step,,,so that i can easily understand,,thanks,,,. PM me,,for the intructions.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 8, 2012 Share Posted March 8, 2012 baui: Did you view the video? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 8, 2012 Share Posted December 8, 2012 meet: I had no trouble seeing the video in post #1. What browser are you using and is it up-to-date? Did you notice that there is a direct link to the video in post #3? Did you try it? Quote Link to comment Share on other sites More sharing options...
